R34 gtr
1999 r34 vspec
Rb26dett
Twin greddy t517z turbos
splitfire coil packs
Nismo 850cc injectors
Tomie 256 cams
Os giken cam gears
GatesTiming belt
Trust 100mm cooler
Greddy hard pipe kit
Apexi power intake kit with pods
Nismo air flow meters
Nismo thermostat
Alloy catch tank
Polished plenium and intake pipe
Copper radiator
Hks boost conttoller
Apexi power fc with hand conteoller
Hks oil cooler and air diversion kit
Nismo fuel reg
Nismo fuel pump with tomie wiring harness
Twin plate exedy carbon d clutch
Stainless apexi dump pipe and full exhaust
Slotted front rotors
Work meister 18x10.5 +12
Bridgestone portenze re002 all round
Z tune style front bar
Carbon side skirt and rear extensions
Longer wing stands
Apexi coilovers
Nismo tail lights
141000klm
Nismo dash
Sony double din screen
Reversing camera
Clarion hx splits up front
Clarion hx 6 1/2 speakers
Hx digital amp
34 vspc plates come with the car
Makes 350awkw on 20 psi tuned by powertune australia
Location port macquarie nsw
Contact shaun
0434390208
Price 69000 or swap with cash adjustment for another jap car wouldnt mind a four door r34 or evo ect
  • Like 4
https://www.sau.com.au/forums/topic/465927-sold-r34-gtr-vspec/
On Tuesday, August 23, 2016 at 9:01 PM, 34GDZ said:
Have you got a pic of this car on the side? I want to see how slanted the superior auto wingstands are
  • 4 weeks later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
