Hello all, I bought a 2004 Stagea (with nav) a couple of weeks ago here in Japan and have been looking for a way to play music from my iPhone other than a crappy FM tuner and can't seem to find a solution. I know there are aftermarket units that can be installed (IDK which one would work on my particular car) and some cars come with AUX (IDK which ones do or don't).
Can someone please tell me how to identify if my car already has aux capabilities and if it doesn't, what the best (and hopefully cheapest) way to either add an aux connection or some sort of bluetooth audio streaming option?
Thanks!
https://www.sau.com.au/forums/topic/465995-play-iphone-on-stock-radio/
Grom audio
http://gromaudio.com/store/all-nis02.html
I have one running on my 2005 Stagea and whilst it has hands free BT (which no longer works), I only use it for charging my phone via the USB and running my iPod.
Does the job, but is not as good as a decent headset replacement obviously.
1 hour ago, iamhe77 said:
Grom audio
Thanks for the reply, which do you have? Does it come with directions for installation?
I have this one:
http://gromaudio.com/store/usb_adapters/nissan_usb_ipod_adapter_direct_digital_interface.html
Yes, it came with installation instructions although you will need to get behind the stock head unit yourself (there are plenty of videos online of how to do this).
  • 4 years later...
On 7/27/2016 at 4:31 PM, iamhe77 said:
I have this one:
heya! I'm brand new to the forum.
I've been searching through the forum to figure out the best way to get my iphone connected to my PNM35 - seems like this is a good option. Did you need to rewire anything with this kit or was it just plug-and-play? (I'm no good with anything electrical) Thanks
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
