Hi guys sorry I know this is skyline not silvia but I couldn't find a Australian based silvia forum.
Anyways i'm applying for the s15 ADM Exemption. I went into Nissan today to get the spec sheet but the guy just went onto wikipedia.... I don't think that transport will accept that if i just printed it off there. Does anyone here have the s15 adm spec sheet from nissan or a brochure ? if you do can you link or post it for me cheers.
We're everything mate. Definitely not only Skylines. :thumbsup:
Just a quick question honestly I'm such a moron..... i sent in my exemption but i forgot that in Australia our spec is called 200sx..... i put in all the 200sx details the engine number ' rego and all of that on the exemption form but under where it says what type of car i put s15 instead of 200sx..... has anyone done this mistake before while applying for their exemption if so did they fail you because of that ?
  • 10 months later...
On 29/07/2016 at 11:53 AM, admS15 said:
Where abouts are you located. I have an adm s15 owners hand book you can have for free. I'm pretty sure it has all the vehicle specs in it. I can check anyway.
Hey, found this thread in a search... realise it's almost 12 months old, but by chance do you still have the adm s15 owners hand book available?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
