Ok. To start with this engine is in a lc gtr torana. So it's fairly tight in the engine bay.  Pic of engine bay is old setup 25neo
I'm about to get my head back for my 30 25 neo and need some help pointing me in the right direction on a couple of questions at the end of the post.
But first I will give you a full spec list of the setup.
Specs are
30 block
Crank welded and modified for 25 oil pump
All resized and nitrared so as new.
Spool h beam rods arp bolts
ARP main and head studs.
87mm Forged arias pistons -10.4cc
Zero deck height
Jim berry modified clutch 4200 pound clamp
N1 oil pump
N1 water pump.
2 x 1mm oil restrictors
1.3mm mls head gasket
Head has exturnal vct mod -3 lines. Ported inlet and exhaust performance valve springs and type b pon cams. Head cc is decked to 49cc
Giving me a 8.5 to 1 comp
Freddie intake manifold match ported
1000cc bosch injectors e85 compatible
Walbro 460 intank pump.
Custom made steam pipe exhaust manifold hi mount
Gtx3582r with 45mm exturnal gate off exhaust housing.
Running 22 to 24psi for pump 98
3 inch from turbo back exhaust
100 cel cat straight through muffler.
The only thing that will be holding it back is I only have a r34gtt Nistune ecu with hpx1 afm at the moment.
I have read several post on here about cam timing and still haven't heard of anyone getting the best setup or no one is willing to let on.
I'm also not sure if I should dump my spitfire coil packs in favor of ls9 truck ones.
Also not sure if I should dump the factory cas for a rossi cas trigger.
Edited by lcxu105
Missed some info
  • Like 1
https://www.sau.com.au/forums/topic/466048-30-25-neo-with-gtx3582r/
 No-one got back to me with the "secrets" of cam timing but my local shop suggested better valve springs but you have addressed that... and I fitted an adjustable cam gear to the exhaust to be tuned on the dyno. What sized rear end do you have on your GT3582R?
The only downside I see to your build is the relatively low CR at 8.5:1 but you may be able to overcome that with heaps of boost. Will not be so crisp off boost.
No need to change the splitfires ( I used brand new OEM gapped to 0.8mm) - if you find they are not keeping up you can change them later. The Nistune may not hold you back so long as you have an AFM that can cope. When and if you change to a more sophisticated ECU you will probably need to replace your CAS with some other kind of trigger.
Depending on the spec of your turbo I am picking you should make at least 400KW
Its a .82 rear on the gtx3582r.  If I can feed more boost into it I will.
Being that the engine is in a lc gtr torana that is only 1000 kgs I'm not to worried about it off boost.
Due to the fact that the 30 bottom end will produce more torque than the 25 neo it should be fine.
5 hours ago, lcxu105 said:
Thanks for that.
Will get some picks when I get the head back hopefully by the end of the week.
Always wanted an LJ. Strangely I am more a 6 cylinder guy than V8s.  I was really trying to get my brother to buy one but I ended up getting him an SS Chevelle out of the US. Mega cruiser but LJ would have been a more entertaining drive
Nice colour! I like the slr style front spoiler too! I had a LJ close to that colour a few years ago, I miss that car 579f36af5cf99_ImageUploadedBySAUCommunit
Id like to see how the 25/30 goes in the torana, I've only been in them with 186's and 202.
Like a cut snake on water.
With the 25 neo same top end less porting and 18psi boost 422rwhp cold do 0-100 in less than 4.2 seconds.  And standing 1/4 in 10.9.
Had it up over 235ks on Lakeside raceway.
I'm looking to make an extra 100hp at the wheels and a shit load more torque.
I hope that the 20g is worth it.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
