Hi All,
Hoping for some advice as I have lost hope after about 30mins lol
So the issue developed about 2 weeks ago when I moved it to wash.
Moving in / out the driveway and sitting idle I could hear a very low constant beep noise, at first I thought it was the turbo timer but nope it's def not that.
I have stuck my head all through out the dash around the drivers side, the best location is above the left knee around the steering column but I still can't locate it. It's a very low pitched beep and if you were sitting in the passenger seat you probably wouldn't hear it.
It also was not present prior to hearing it.
Any help is appreciated.
https://www.sau.com.au/forums/topic/466229-low-faint-beeping-noise-r33-s2/
Check for a small speaker looking unit behind the drivers side door card
other thought was an aftermarket alarm with a dead/dying roll of watch batteries
perhaps even a hidden turbo timer behind the dash
  • Like 1
Depending on the sound it could be some sort of earthing issue. I know that one of my old cars made a low pitch whine when it was started. It varied with the RPM of the engine.
One thing I can suggest is to double check your terminals on the battery (assuming you don't have two). Make sure they are super clean and tight. If your car has a separate earthing point to the chassis (normally located either at the front of the car or near the strut towers), check the earth. If this is in poor shape you can introduce all sorts of odd harmonics.
The other sound that it could be is a dying capacitor. They make a funny squealing sound when they are dying. Do you have any electronics (PCBs) mounted in the area that could be the source?
^^^ That said if you are absolutely sure this is a beep and not some spurious noise, you need to look for electronic boards. You will most likely be hearing a piezo speaker. These are generally smaller than a 5 cent piece and are mounted within electronics, so are hard to hear.
Most smart (read: well designed) items will start to beep if the board detects a lack of power.
Quote
This is most likely the reason, most of the circuit will be receiving 12V (or thereabouts) from the car and will operate fine, but the backup battery (normally a lithium watch or button battery) may run on a different area of the board with it's own power sense circuit. When the power drops the circuit will move from it's normal mode of operation, to a circuit that include the speaker, thereby creating the beep.
I'm not familiar with enough of the R33 electronics or any of the aftermarket items to know what it could be, but you may find it's as silly as the clock or radio in the car.
I'd suggest (if it bothers you enough) to pull off any trim in the area and try to isolate the sound. It could be coming from deep within your dash.
Yes that's the stumping part.
Only when the car is on it beeps.
It's comes from around the steering column.
I'm going to spend some more time on it as I noticed the greddy control boxes are shoved around in there ( I assume control boxes for boost and oil temp gauge ) I seem to have a sneaky suspicion it may be either of them cause that's the only items in the vicinity.
Also ripped out the turbo timer and still doing it.
  • 3 months later...
  • 7 months later...
  • 1 year later...
Any solution to this ? I have similar situation in my skyline V35, 3 beeps at ~1 every 2 sec interval even without keys inserted, lower than the sound it makes when I leave the keys in with door open. Does not make the beep sound when I have car running though.
Edited by kool
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
