Hi as title suggests I'm using an RB20 ecu to run my 25 drift sled and the vct doesnt seem to be working. Can not hear the solenoid click at all, have tried jacking the car up and had the wheels moving and still doesn't seem to work.
As far as i can work out the tuner has tried to use the air con signal pin in the ecu to try and trigger the vct. From the looks of it it seems to be done right, I'm starting to wonder if this is a software problem and he hasn't flashed the ecu to now know to use the air con...? He said he didn't know if it was working or not but didn't have time to check as we had other dramas that day with the car..
can anyone confirm that this is how you do it?
thanks
https://www.sau.com.au/forums/topic/466328-nistune-vct-wont-work/
i haven't got the software myself that's what i needed the tuner to do but i was trying to work out if it was a mechanical problem or a programming thing. Tbh he didnt seem to care if it worked or not which is annoying as that's one of the things i needed him to do..
yeh i don't think the vss is needed in my case as I'm trying to trigger it with the a/c as rb20 ecu doesnt have vct option at all. The other option in Nistune's manual is to use the fuel pump idle up pin as apparently the ecu adjusts the standard fuel pump but when you upgrade to better pumps this is no longer needed. This sounds a lot harder, messier though.
 I just wanted to see if how hes modified the board is correct as there's no diagrams on Nistune's site.  I'm pretty sure he just hasn't uploaded the files that let the ecu know that your now using the a/c so the solenoids not getting any signal atm....
Perhaps he hasn't flashed it with the correct firmware.. you have 2x options either trigger it from the green LED output OR use the AC trigger out.
You really need the Nistune software, consult cable to work this out.
Where are you located? I have a tuner license... will diagnose/fix for slabs of 150 Lashes
If the feature pack firmware is not installed you will need the ECU reflashed.  This is not the same as just using Nistune software to alter the tune, etc.  This is using the Nistune programmer.  Not all workshops that tune Nistune are "dealers" that can also program the boards.  You will need to ask your prospective tuners whether they are capable.  Any one of them should be able to tell you whether the feature pack firmware is installed though.  Nistune helpfully tells you if it is as you connect.
I was saying to use Nistune to see if he has the correct firmware.. and if he does, is it actually setup correctly.
Matt from Nistune will flash them for free, just pay for postage back.
Matt from Nistune will do a lot more than that.  He has performed deep surgery in my ECU on a couple of occasions to help me get the air-con working post Neo transplant.  Turns out that along with all the (simple) wiring problems of trying to use R34 ECU to work with R32 climate controller, my ECU was borked.  Had dud circuitry.  Matt spent a lot of time and just happened to have spares of the rather esoteric devices needed to repair it!
In one of the older software versions, there was an issue where the VTC attributes in the address file were crossed up, effectivly making the logic impossible to activate it (unless you knew the issue was there, and could swap the values accordingly). I had this issue personally.
Can't recall if it was ECU specific (type 2 Z32), it was the rpm engage/disengage fields that were ass about.
rb20 ecu cannot run vct. since rb20s never had it. it needs to be run off a trigger from either a boost controller with an aux output or a switch.
only way to get it to work as per normal would have been by using a z32 ecu instead of rb20.
This is no longer true.  Nistune's new feature pack firmware has changed this.  Which IS EXACTLY WHAT WE SAID ABOVE!
No, you're wrong.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
