So I've had my R33 for a few months now and I've recently been having boost control issues. I have Greddy profec B Spec II and its acting very strangely. It drives fine and holds boost until it hits peak boost (14psi) then it will no longer make any boost. The display says it's making around 1psi. But then after leaving it for a while it will work fine again, rinse and repeat. Is it the solenoid sticking open? Any help would be great.
Cheers
https://www.sau.com.au/forums/topic/466339-boost-control-issue/
Well if it works fine with the boost controller unpowered then the issue definitely lies there. The thing is, if it's switched off, the lowest the boost can go is wastegate spring pressure and i would expect that to be between 5-7 psi. You said when it plays up your only getting 1 psi. Since you have an aftermarket split dump, i would definitely check the flapper opens and closes smoothly and doesn't get caught open. Some of the split dumps have a reputation for causing this. Wont take long to check and rule it out as a possibility if it's all good. Cheers.
You're going to have to determine why it's sticky. Most probably it is fouling the inside edge of the dump pipe. You will have to take the dump off to take a look and either dremel it for clearance or replace it with a bell mouth dump. The other possibility is the flapper mechanism itself is faulty and sliding in and out. Pull the dump, diagnose and then take action. Cheers.
No probs. You could also try spraying some wd40 or similar on the shaft of the flapper and open and close it quite a few times and see if that frees it up before you go pulling shit off. I use to have a turbo on an old car of mine that had a sticky gate and doing that would remedy it for a few months. Give it a shot, can't hurt. Good luck
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
