  • 4 years later...
  • Replies 51
lol Sydneykid- you started the original thread years ago...
http://www.skylinesaustralia.com/forums/To...l&hl=towbar
and a few others:
http://www.skylinesaustralia.com/forums/in...t&p=4382443
The most common is a "max" (contact details in the 1st thread towards the end). It is rated to 2 tonne. Cost me approx $700 delivered + $150 installed, and it has towed my evo to interstate events without any drama's :P
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573107
Here's mine.
Cut to expose the rails then side in box section. Bolt thru into the box section for a solid fit.
1500kg braked.
Job was ok as they should have sealed the exposed metal better, will sort that later.
I'm in New Zealand, cost $299 installed with wiring. I removed the rear bumper which saved a lot in labour.
Rhys
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573186
1500kg tow bar on an M35??? thats very good!!
Yes more than enough for what I need.
I did have to mod the small plastic left and right trays where it shows the photo of the plate in the boot so they sit flat.
People love how neat it sits on the car. Just the tongue sticking out with no ugly bars hanging down.
My custom exhaust from turbo back is getting finished tomorrow so will post photos up later. Going for the 'Remus' look :P .
Rhys
Edited by StageaM35
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4573544
I'm thinking it would be handy to get one, too. Not so keen on hacking up my 260RS body kit for the tow ball though. I wonder if could hide the whole thing and just remove the lower 260RS add-on part of the rear bumper when I need to tow something..
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574199
Just had a word with him.
$220 NZD for the towbar, no wiring/plug but can be supplied (It's about $20 for the plug and wiring but you guys could source that over there).
That's for an order of 5 towbars.
The more that are interested the better.
Shipping price I would have to get them to look into but the cost can be broken up between you guys.
Cheers,
Rhys
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574680
i think im in! even if i only use it once, being able to tow something would be awesome!
I think I'm in too.
So $240NZD inc wiring.
So what would shipping be?
Since most of the guys here are in Sydney, am I (we) looking at more for Melbourne?
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574896
shipping OS is shipping. i dont think the destination matters much. only the setup of his jig to make 5+ at once is worth his while.
anyway, Rhys if you dont mind looking into it, i believe you have 2 people already!
there are plenty of M35s on the forum also.
do you mind taking a picture of the outside of the car with the bumper on please, post-install?
and does your M35 have a standard rear bar or an Aero bar etc??
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4574928
Rhys
Yeah that looks good mate, more photos thanks, with bumper back on etc. Where abouts in NZ? Saw a silver one at hamilton nissan dealer recently that had tow bar, only time in nz so far. Also what have you done with original exhaust, i see you have the twin exit pipes on final muffler. My 250RS came with the big bore look but quiet end pipe, not a fan of that look and doesnt really suit it etc. Would like that twin pipe end mufflar.
https://www.sau.com.au/forums/topic/46643-tow-bars/#findComment-4575046
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
