Hola
Hello everyone,
I've been around R31s for quite a few years, purchased my first R33 a couple of months back and love it. Already spent some coin on it, with much much more to come. Looking at making it a reliable 300kw street/track car.
https://www.sau.com.au/forums/topic/466595-hola/
It is a S2.
Currently has: GFB elec boost controller, GFB elec blow off valve, FMIC, 3" magnaflow exhaust, Extreme twin plate race series clutch, Tein coil overs, break upgrade
Planned: Larger turbo, plazmaman intake, upgrade ignition system, upgrade fuel system, aftermarket computer, E85, tune, upgrade suspension, eventually forged internals.
4th gear syncro is on its way out so ill throw a new gearbox in it next and then swap out the diff to a stronger LSD. should make for a reliable fun car. My target is 300rwkw.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771865
Hey mate, welcome. Before you go changing gearbox, you may want to check how much oil is in there. Mine used to crunch into fourth at high revs and it turned out there was only 2.5 litres of oil in it when there should be 3.6 - 3.8 litres. I changed the oil and refilled with the right amount and the box has been beautiful since.  Worth a try before you go to the effort of changing boxes and obviously the cost of it too.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771866
The mechanic that put the clutch in couldn't get the drain plug out of the box to change the oil, so there is a good chance it may be low, i might find a hoist, have a crack at the plug myself and throw some oil in there.
thanks
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7771943
Got it on the hoist, took about half a litre of oil, took it for a drive and 4th gear is still troublesome, it is only at speed that it has an issue which is a little confusing, I can't engage 5th to 4th, but I can if I go 5th, 3rd, 4th.
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7774501
drop in Nulon Smooth shift addictive, usually helps with these shit boxes (literally)..
Mine grinds in 2nd at 7k rpm, but a workaround is to bash the limiter and slip it into gear... 3rd and 4th grinds too, work around just shift as hard as you can "reef" it into gear LOL... #traklife
Yours looks so much cleaner than my shit box :)
Does it dose good?
https://www.sau.com.au/forums/topic/466595-hola/#findComment-7774678
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
