Hey all,
Just got the head for my rb25det neo back from being ported and reconditioned..
I have noticed the front intake cap appears to have been damaged in transit.
It is not perfectly round where the seal sits, there is also 2 small cracks, 1 where the seal sits and another on the top surface.
I understand these caps cannot be replaced without getting the head linebored.
Would this cap be OK to reused considering there is no damage to the surface that sits on the cam?
I have emailed the company that reco and ported my head but won't get a response till next week..
If I was to try and recoupe my losses through the transport company it will likely take a long time and I may still be down $$$ to get a new head or get this repairedc9b27bd305a80b789e5cdb4cb20aba22.jpg158cd4a0c7ecb9fcf932258cd668858a.jpge35260a8a0e3d59daecf7c9318a2b4ae.jpg
https://www.sau.com.au/forums/topic/467499-damaged-cam-cap-on-fresh-head/
Better off not to dodgy up that damaged cap.
You can find a cap off another head and fit it without necessarily needing a line bore. It needs to be dummied up, measured and checked that the cap sits concentric with the bottom. You would want to get the engine re conditioner to do this because they will have the measuring equipment required. I've done this in the past with success after a cap mysteriously went missing. The heads would be machined with good enough consistency in the factory that a lot of caps could possibly be interchanged between heads.
Thanks mate, I'm pretty pissed off at this point just seems to be one thing after another. I will have to wait until Monday to get a response from the machining shop but hoping they had some sort of insurance on the freight.. if a cam cap cannot be sourced is having them line bored a practise that has been done before and would it be a very cost effective repair?
Not sure on the line bore because i've never had to do it. You'll find out from the workshop once the easier options have been exhausted i guess. Put out a wanted to buy and see if people have got any old heads laying around to pinch their caps.
Just by chance I may have one floating around in the garage at my mum's house. I'll let you know by Monday.
I'm running with an other cap that the one the head came with. Two trackdays and some km on the roads and no signs of wear on the cam nor the cap so you can use another cap if needded.
This cap is not extremely loaded because the timing belt is pulling the cam downward and all the efforts of the springs on the 1st cylinder are handed by the 2nd cam journal. This one is really just the support for the cam seal.
And the fact that these cracks are black inside mean that they are there since a while, you just didn't noticed them before I think.
Did you ream or linebore the head, or meaure it when you put the other cap on?
It was definitely not damaged before, it would have been picked up by myself or definitely by the machine shop, and there was another mark on the front of the head where it looks to have been dropped.
Regardless the head is back off and packaged up to be sent away on Monday..
Nope and nope.
I fitted the cap without the cam to "check" the alignement visually but didn't measured it nor linebored it. As it sat flush with the head I just installed the cam and tested it but checked it twice since the installation (after each trackday) and nothing to report, it work as it should.
Do you think that the head fell off on the cam cap during transport ? The box where the head came in should show some trace of this shock. Anyway this will take time to get it repaired. Given its position I wouldn't mind using an other cam cap, doing it in the middle of the cam where the cap is taking effort from the spring is another story and may need a linebore. But this one is "replaceable" to me as it is not as critical for the cam function, it's there more for sealing purpose.
I understand what your saying about the front cap having no load on it, but its off already and the risk is too great..
I didn't really preserve the box for inspection when I unpacked the head, but I am sure it has been dropped. I got the head back 4 weeks ago but it has been sitting boxed up on the shelf waiting to be installed, If that Is enough time for the cracks to turn black.
There was no insurance on the freight and I expect I will have to cop the full cost of it myself
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
