R33 GTR 105,000kms $22,000
Up for sale is my 1995 Nissan Skyline GTR. I purchased this car as a bit of a project but have since bought another car and lost interest.
I bought this with a blown motor but have since got another low milage running motor for it and had the head fully reconditioned, bottom end inspected which was fine and put a genuine Nissan VRS kit through it. I have taken the car for a few drives since the new motor has gone in and it runs flawless. I was getting this car ready for a roadworthy but it has just sat under a car cover for a few months so I have decided to part with it. All reciepts since I have owned this car will be supplied (over $2000 spent not including the motor). It will come with no RWC, rego or plates but as far as I'm aware will need 4 new tyres, possibly the rails fixed and that's it to pass a roadworthy.
Car was tuned by RacePace when it was owned by the previous owner at 325.6kw atw but the boost controller has been removed so is now running wastegate pressure on the tune.
Blitz coilovers
Buddyclub P1 18x10 +12 wheels
Adjustable front and rear camber arms
Adjustable front caster arms
New sway bar links
New driveshaft boots
100,000km major service was done before I purchased the car and confirm the timing belt, water pump and tensioners are all near new.
-7 turbos
Adjustable cam gears
Splitfire coilpacks
Custom twin 2.5" exhaust (seperate off each turbo)
Alloy Koyo radiator
ARC airbox
Cooling panel
Oil catch can and washer bottle combination
Bosch 1000cc injectors
Power FC D-Jectro with MAF sensor
Walbro 400 lph fuel pump
Brand new Exedy heavy duty clutch with freshly machined flywheel
Nismo 320km/h cluster
Nismo shifter knob
Triple gauge cluster
Nismo clear indicators
The bad:
Chassis rails have been jacked up off of and have crushed them on both sides but they are very repairable (pictures supplied).
Paint is cracked on the front bumper.
Spoiler is fibreglass and paint is cracked but will come with a genuine wing that needs paint.
Car needs a good detail but will come up really well.
Any questions text me anytime or call me after 5.00pm.
I have been as truthful as possible with this ad so please don't come see the car pick on it and low ball me I will tell you to leave. The modifications alone exceed the price of the car so I think it's a very
good price.
I am not interested in swaps as I have another car.
Car is located in Geelong, Victoria
$22,000
David
0447 triple nine 751
Edited by Muratori
https://www.sau.com.au/forums/topic/467729-r33-gtr-105000kms-22000/
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
