F50 BREMBO KIT FOR SALE
Items will be shipped from Hong Kong as I am no longer using. This will come with all bits to complete bolt on R32/33 and i believe you can make the mounting holes larger for R34 GTR.The is a 4 pot big brake kit with 44mm/40mm aluminium pistons with much better cooling and power than stock r33/34 Brembo. 2pc 330mm Disc with endless CCX pads. Looking for USD$1800 shipped.
Edited by AHSAM421
https://www.sau.com.au/forums/topic/468155-f50-brembo-kit-for-sale/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
