V36 250gt hesitates when taking off from stop
Hi everyone first post here and I really need your help!! I'm located in Auckland NZ.
My 2007 v6 250gt (vq25hr engine) hesitates when accelerate from stop with light throttle. Rev goes up to around 1200rpm and suddenly drops to around 900rpm then up again to normal. Car would shake and lose power for a blink of time. It ONLY happens right after the car is warmed up, say after 5 to 10 minutes of driving. No problem at all when engine is cold and the symptom goes away after another 10 minutes drive.
I started noticing the issue after I cleaned throttle body and replaced battery.
So far I have put new battery in, cleaned throttle bodies and MAF sensors, changed air filters to kn. Reset ECU by disconnecting battery and releasing remaining charge by pressing bake pedal. I have also done all the relearn processrues. But none of them made any difference.
There is no CEL or code.
I have even swapped two throttle bodies and MAF sensors but that didn't help neither.
I am having bad mileage too at 7.2km/l when driving moderately in city.
Any ideas??? I have read so many posts and don't really know if I should have a software update or change the exhaust valve or ???
I'm so frustrated:(
Thanks!!!!
This sounds like something similar to what affects some early V36s where the engine coolant has warmed up, but the oil isn't yet fully warmed.  the VCT is quite sensitive to oil viscosity and doesn't function correctly while the oil is still thicker.  i think there was an ECU update to extend the time after warm up before the VCT starts functioning, but it can be hard to get updates for JDM vehicles once they are outside Japan.
Perhaps try a different type of oil..
  • Like 1
Hi Somicii, thanks for the reply! Yes I suspect it's the VTC as well.  I have opened the VTC cover to remove any jam or gum but it turned out all clean. I'm currently using 5w-30 and will change to 0w-40 which is thinner in next service. I'll post back how it goes with different oil.
cheers!
On 1/1/2017 at 9:07 PM, 30ONA said:
Vacuum leak? Check the intake pipes aren't cracked or loose.
Hi mate I have checked all pipes there's no sign of leak plus idle is stable and once car is fully warmed up symptom goes away immediately.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
