Help with Series 2 tail lights and trailer wiring
Heya so I have a few questions,
Went and got some Series 2 tail lights and installed the tail gate ones, although I did have to scrape off the black gooey silicone tar looking stuff and reuse it on the series 2 set,
Where can I get some of that tar sticky stuff that's now stuck on my hands forever (New Zealand please)
And, little did I know the side tail lights fit but need different indicator bulb plugs
So where can I get the indicator plugs from? I'll head to supercheapauto and repco tomorrow to see if they have any but I don't feel too confident that they'll have anything.
And because I need amber coloured indicator lights now, does anyone know the bulb number/part?
And because the previous owner of my car had series 2 lights and took them off at sale he cut all of the trailer wiring, so I wanted to know when doing the trailer wiring do I just place the trailer wiring into the light bulb plug? where the normal indicator wires go etc?
Now before you say use the search or what ever, I did, but nothing about rear tail light bulb plugs (Maybe i'm not using the correct names?)
Thanks!
Repco will have amber light bulbs. Why do you need amber bulbs anyway? Looks as though you have amber lenses... or are the top white ones indicators and not reversing lights?
Trailer wiring as per diagrams (you'll get them all from the drivers side but will have to bring a wire over from the LH turn indicator)
http://cmtrailer.co.nz/technical/typical-trailer-wiring-diagram
  • Like 1
Cheers, do you know about the 'socket' or 'plug' that the light bulbs go into?
And with the wiring, does the actual bare wire go into the 'socket' or 'plug' as such?
IMG_1482829047.860562.thumb.jpg.551051a4
Or in other words where does the end of the wire get plugged into
You need to buy a trailer plug and a length of 7 core trailer wire. One end goes into the plug and you have to bare the ends of the 6 or 7 wires at the other end. Ideally you solder the joints and cover with shrink tube but otherwise you can use individual connectors. If you buy the flat connector and the 7 core wire from an auto electrical supplies rather then Repco or Supercheap they may be able to give you some tips on what to use for connecting the individual wires to the car if you are not going to solder the joints.
Here is a video for the socket end:
OK in case you need it I found the notes for my S1 trailer wiring (7 core wire colours first)
all on RH rear
white to black
brown to green/white
green to green (RH)
red to green/yellow stripe
but
yellow to LH side of car - green wire for LH indicator (may be different on your car - use multimeter to check (or just a test light probe).
all on RH rear
white to black
green to green (RH)
but
Cheers! Exactly what I needed,
I don't suppose you have a photo of behind your RH tail light so I can get a grasp of it?
Otherwise what type of connector would I use to join the wires together as I have no tools to solder
Refer my previous post
I'm wiring it up now, you mention yours goes white to black, I have two black wires, one for indicator and the other goes to the brake light.
Do I wire it to the brake light or two both?
White is earth so if both black wires are earths then either should do.
Thanks a bunch mate, super helpful. Got the tail lights all wired up and the trailer lights working.
Repco had the light bulb socket thing, it works, but not really. So I had to silicone it in there lol.
Series 2 looks so clean, got it for a bloody good price $200NZ considering people were asking $350NZ for just the tail gate ones...
IMG_1482903083.082098.thumb.jpg.b54473d8
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
