R33 GTR stuff for sale (Brakes, Cams, Cluster, Fuel Pump, Injectors, Brake ducts)
R33 Front 4 Piston Brembo Calipers with Endless Disks & Pads:
Came of a 97 GTR with 120k on it.
Includes:
Endless 324mm disks (29.5 MM thickness currently)
Endless MX 72 Pads (i am not 100% sure on the pads, but was told these are the pads on the car when I bought it. On the back roads once pads were warm I never had any issues slowing down the car in a hurry)
$1100
272 Kelford Cams:
Unsure of what the exact specs of these Cams are (i.e. lift), but they are 100% drop-in into a RB26 (no need for Valve springs and all that jazz).
Looking at Kelfolds website it seems to have 8.9mm lift and they are L182-4:
http://www.camshaftshop.com/products.php?productid=1052
Removed them as i wasn't a fan of the lumpy idle.  With these Cams and HKS 2530 @ 20psi, i was able to make 406 rwkw on E85 (made 370 on 98).
Cams were in the car for a maximum of 30k kms.
Cams are at Racepace, so they can be inspected after the 9th of January (currently closed for x-mas break).
$550
R33 Series 1\2 Brake ducts:
Bought them in the hope they will fit a S3 lip. Don't want to cut them up to make them fit.
$180
R33 Triple 3 gauge singe din cluster:
100% working.
S150
R33 GTR Cluster (non-vspec):
Has ~ 65k on the clock.  I can't 100% confirm everything is working on this gauge.  I bought this gauge from the Wreckers, when my rev counter on my gauge stopped working and i was waiting for the Nismo cluster to come in from Japan.
Nismo cluster arrived a few days after i bought this part, so never got a chance to put it in.
I did notice something strange on this cluster though. On the bottom of the cluster where you get the 4WD light & Hicas light, this cluster has a Cruise light instead of the 4wd light (more curious to what sort of car this came out of now).
$150
Fuel Pump -  DeatschWerks DW300:
DeatschWerks DW300 Fuel Pump rated at 340 LPH
$90
Denso top feed 680cc injectors:
Came of RB26, which pulled 370rwkw @ Racepace dyno. Injectors where at 90 duty cycle at that power level.
$240
All parts are located in Melbourne (South Morang, VIC 3752) and prefer pickup.
Also happy to meet buyers at Docklands or Eastern Suburbs.
I can be contacted on 0422 Three Two One 10 Four
Umm...this is strange.
When viewing the ad from a web browser you can see the listing for the other parts, but when you view it from the sau app, you only see listing for the first 2 items.
I'll cut and paste the remaining items from the browser to the app tomorrow.
Anywhoo, ducts are 180 ono.
Located in Vic 3752.
Reposting due to some items not being visible via app.
Includes:
$1100
272 Kelford Cams:
$550
$180
100% working.
S150
$150
$90
$240
 Share
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime.
    • I was able to complete installation of the G4X ecu. I needed to reroute MAP vacuum signal from stock location to where BOV is connected on the intake plenum. Has anyone needed to do the same? When I connect vac port by the BOV flange to my HKS BOV, it doesnt work and I get flutter. I would to get BOV working, where would it be best to T in? Or would it best for me to move MAP vac line and T into FPR? Secondly, I installed a MAC 3 port boost solenoid and wanted to know if i routed it correctly. I place two lines from stock boost solenoid and placed it on ports 1 and 2, leaving 3 vented. The T for wastegate and boost source on compressor elbow is on port 2, and port 1 is connected to turbo inlet intake pipe. Please see attached pictures. Ill upload ecu config later today. Thanks in advance.
    • some people are still around weirdly enough - most people just use facebook now to ask the same 12 questions tho XD
    • Omg Rezz! Yep we're still here and actually seeing a trickle of oldies coming back.  How's things?
    • So I raised the car up a fair bit for shipping - see image - then lowered it again when it arrived. I then rushed to get an alignment in NL before the track and the shop just wasn’t anywhere near as precise as what I got in Japan. The guys that did the alignment this week said there was a fair amount of toe in the rear that could have contributed to the understeer. It was also the case that the rear camber went from about -2 to -3 at the shop in NL. However, since I’ve now got slightly wider tires in the rear - NS2Rs run wider than Accelera 651S - I could only get a minimum of -3 in the rear now due to clearance. Front is now -2.75 (-2.45 in minutes) due to being raised a bit (previously -3 in JP). So it’s likely a combination of the two factors, camber and toe. The issue now is I have more camber in the rear than the front and the next step on the front Cusco arms will put me at -3.5ish front which seems a bit excessive to me. The weird thing is I’ve never had any understeer at the track in Japan but they are very different circuits - Japanese circuits are much slower than the one I’ve been to here.    I’m probably going to have to start another thread for the E90. The plan is sort of to keep it as a daily but progressively mod it into a track car - honestly, you need a cage for the sort of speeds you go here. Just ordered the M3 front arms btw.  Love the car despite it being in pretty shitty condition. Oil analysis came back okay and it seems to have stopped consuming oil since fixing a load of engine bay things. Saw yours is a 335i right? f**king mistake on my part getting the DI N53 over the N52, fuel economy is insanely good though at 14-16 km/L.   Cheers, it’s great to see the benefits and pitfalls of different places. I’m contemplating going back to the U.K. around next year as the cost of living in the Netherlands is just ridiculous. GF is nagging me to settle and buy a house but I don’t know what LSD to buy.
