Newb
Hi guys,
I'm a new member and thought I'd introduce myself. I'm Adz, live in Canberra. I'm the proud owner of a 1988 R31 GX Series II.
I have some pretty big plans for this car, and already have a few parts to add to it, thanks to my best mate. I'm basically aiming for the car to look like the second pic below! :)
My biggest issue at the moment is trying to determine what would be the best suspension conversion (other than s13) for the car being a dedicated track car (hillclimbs, sprints etc)
Any advice is appreciated.
Cheers :)
  • Like 1
https://www.sau.com.au/forums/topic/468528-newb/
i love a good 31 build.
welcome mate
i remember back in the day on the r31skylineclub forum there were coilover kits which you could weld the r31 hub to. these were the best option i saw when going through the motions. the S13 stuff worked but the highest settings were still very low.
**edit**
found it, Angrys kits.
https://www.facebook.com/pg/AngryIndustries/photos/?tab=album&album_id=115545405206002
Edited by GH05T
https://www.sau.com.au/forums/topic/468528-newb/#findComment-7803578
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
