Need help with R33 roof rack fitment
I'm looking for advice on roof rack fitment for the R33, and/or someone with an R33 who might have time to drop by a roof rack shop (ideally one I normally use in Artarmon, NSW) in exchange for a bit of moolah.
Searches indicate Thule once produced a setup for the R33: fit kit 235 mounting 950 feet, a short roofline extension kit and square bars. Chatting with shops, it sounds more promising to instead work out what modern fit kit works with today's 754 feet. On a UK forum ben_harmer32 made use of fit kit 1228 for this purpose, but the positioning achieved by a subsequent poster with such parts looks sketchy.
  • 3 years later...
I know you posted this back in 2017 but I'm traveling down the same path. I located the short roof adapter and feet but I'm still on the hunt for a working fit kit. Now the parts that match the feet are all obsolete so the information and parts are harder come by. In the 1228 setup that you referenced  it looks like the last post has pictures that don't work. In that one the bracket is too short. It doesn't allow the rubber to sit above right or the crossbar to be parallel to the ground.
Did you find a fit kit that worked?
I'm now looking for the fit kit 2121 which has bracket 08 and rubber 26 but I've only been able to find them separated.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
