I've just been looking around the Ford web-site and didn't come up with much.
I'm looking for the following figures: XR6 RWKW, XR6T RWKW and XR8 RWKW.
I know a few of you drive them. Then again, my old man has one and doesn't know. His guess is around 180 KW at the fly for the XR6.
Out of interest, I also wouldn't mind knowing the Holden figures for the S, SS and... whatever else Holden have.
https://www.sau.com.au/forums/topic/46945-ford-power-figures/
  • Replies 60
Barra 182 - XT, XR6, Futura, Fairmont, Fairmont Ghia
182kw @ 5000rpm
380Nm @ 3250rpm
CR - 9.7:1
Barra 240T - XR6 TURBO
240kw @ 5250rpm
450Nm @ 2000 to 4500rpm
CR - 8.7:1
Barra 220 - XT Sedan (optional), Fairmont (optional), Fairmont Ghia (optional)
220kw @ 4750rpm
470Nm @ 3250rpm
CR - 9.7:1
Boss 260 - XR8
260kw @ 5250rpm
500Nm @ 4250rpm
CR - 9.5:1
you beat me to it
That web-site is good.
Is there any sort of standard way to convert between factory power figures and actual RWKW? How accurate are factory figures?
Not really, RWKW is after drivetrain losses, and the drivetrain losses are different with each car
Roughly (I have noticed anyway) flywheel KW ~ rear wheel hp
the fords XR6T and XR8 will have around the 160-180rwkw stock ..... they r similar power figures to the holden GEN3 (LS1)..... alothough the fords r ALOT slower, they weigh about 200kg more than holdens similar make....
XR6-100-120 rwkw
s(ecotec 3.8l) 100-110rwkw
ss(gen3) 160-190rwkw
HSV-GTS,clubsport, senator,grange 180-230rwkw (heavy car tho)
ATM go XR6T they r easy to get power from and r pretty reliable, but if u want that V8 sound go gen3 with just bolt on mods the boys at (www.ls1.com.au) r running low 12's.......... and 11's with a stock bottom end.....gen3 can have a piston slap problem so make sure u suss it out b4......
if u go the boss XR8 engine u just wasted $60,000, u need to take the engine out to put extractors on and if u drop a spanner in there u won;t get it back out....
dunno if it helps, but a mate has an XR6T with a few mods (exhaust and boost), and it dyno'd 331rwhp
dude u get ur facts correct b4 u make statments like all XR6T beating SS? if u want to go to stock performace just open ur "MOTOR" magazine and c.....
ur right with the xr6 4.0 and ecotec 3.8 s ....... the ford will win... not by much
331rwhp XR6T not a good effort.... .....did u visit the website i put in the post (www.ls1.com.au)......
bolt on mods inc edit
twin 2.5" zorst wit extractors
Mafless edit
2500rpm stally
CAI
i don't think i am missing anything
will comfortably c 230-260rwkw..... wack a set of semi slicks on it and will c a low to mid 12 second pass..... for wat $2000-4000
do a bit of head and cam work and u will be seeing low 11's
the XR6 turbo is a awesome car and like APS demonstrate they r very quick but u can't compare the difference between kw per dollar...... and m8 wat u c on the street (assuming) really don't mean shiat........i am just learning about skylines (because i think there great cars).... but don't blab on about stuff u don't know or r not sure of........
if ur still a bit unsure have a look at these threads where they compare the two cars from both perspectives down the track
http://www.ls1.com.au/forum/showthread.php...&highlight=mods
http://www.fordxr6turbo.com/forum/index.ph...opic=10267&st=0
Well for with mild mods the aps phase III xr6t has run a 10.98 and is street legal. This package I think costs around $8000 and the the cars intial price tag is only around $45000, so in my opionion mildly modded fords are winning the battle at the moment.
i c ur point and i spose ur right althouh the genx kit for the gen3 (supercharger) costs $4500 and with a bit of tuning u will be running a high 10.... but if i was to spend that money on a new car atm it would be a xr6t .... it would be a much nicer car to drive to i think.... but u still can't beat that v8 sound...
i agree and i think ford r wining atm and with the arrival of the typhoon they will jump even more ahead .... but u just wait
i will let u on a bit of an insight
the coupe4 (awd v8) comes out next month... this kicks off the holden awd
then late this year the VZ HSV's come out with a 6.2L gen4 350kw (not confirmed yet) then not long after that there will be AWD 350kw HSV's, even the ss(6.0l gen4) get the AWD.... so there will top Aussie beasts running around town..... and then u have the fools that will wack the fatest supercharger onto the side and will probably see a easy 9 second pass......and hopefully have the handling of a GTR :flamed:
cant remember which mag i read it in, either motor or wheels, but the XR6T had the acceleration advantage, but i this was when it was first released, holden have upped their power a bit since then hey?
is the coupe4 coming out in both auto and manual, i heard they were only doing an auto?
the coupe 4 is only comming out in auto only..... this months wheels have got there hands on 1 and have an article on how it goes.....
by the time the HSV's get the gen4 and the awd there should(most likley) b a manual option.... and there will be a 5 speed auto comming out in the next model "VZ" comes out soon.....
ohhh and my quote "9 second pass" .....
i don't think it will be easy..... i think there will be "alot" of drivetrain and weigh problems.....
and speak of the devil my dad just said tonight he is keen on getting a XR6T..... i will have to line it up against my senator :).... i don;t think i will try and convince him to go holden as the new V8's r wat detered me from getting a new one and hence why i went the old skewl 5.7L.... i think my next car will b a GTR R33 :wassup:
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
