EOI: gtx3582 gen2
I have the gtx3582 gen2 on my car for 1200kms. I want a little more response so I might change to Gtx3576 gen2.
if someone interest my 3582 gen2, pm me please. Price will be around 2300 and you can have any size of rear housing because I will keep the old housing and buy a 3576 gen2 with the rear housing you want.(they only sale a kit, no supercore)
locate Gold Coast.
https://www.sau.com.au/forums/topic/469483-eoi-gtx3582-gen2/
Car made 540hp awhp on 24psi e85 0.83ar
610hp awhp on 26psi.  E85 (2 more psi = 60hp)
0.83ar
I think it will make 650+hp on 28psi. Or 700+ on 30psi.  It's a happy turbo if go north of 25psi
Let me know if someone interest it.
I used have gtx3576 gen1 with rb26. It spool 600 rpm early than my 3582 gen2 with 2.8.
If no one interest my 3582 I will set the 8700rpm limiter. Then I should still have same power band as 3576.
Edited by Nosure
  • 3 years later...
Hi mate. Wondering how you ended up going? Did you go for the 3576? If so what were the results? I'm currently on -5 twins having just tuned to 370kw at 20 pound, but I'd like to simplify the bay, see full boost 500rpm earlier (currently ~4500) and possibly get to 400kw on the same boost.
I've read mixed results about the 3582 gen 2, thinking I'd get better response and not lose top end with the 76 rear instead.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
