Looking for a power upgrade for my R33 GTST, have been offer a set of T04E turbo with RB20/25 ex manifold, and wastegate.
At moment, my car has standard exhaust system, Blitz pod and power fc. (FMIC is on the way coming..)
Some pic:
T04E
RB20/25 ex manifold
wastegate
1) Just wondering is the RB20/25 manifold interchangeable? (had varies answer from different source....I meant not try to modify it)
2) From the pic of ex manifold, Will or what other turbo can fit the flange?
3) Will the T04E laggy? what rpm we talk about the turbo start spool? 2500/3000/4000?
4) I assuming that I need a customise dump pipe made for it right?
5) Injector will be something need to look into, say 550 cc? with a GTR ot large Fuel pump?
thanks in advance.:mad:
https://www.sau.com.au/forums/topic/4696-t04e-ar60-on-rb25det/
yeah you will need a new exhaust system not a stock one the rb20 and 25 manifolds are the same. in most cases.
injectors, bigger fuel pump ,managment, afm etc etc.
it depends on what you want do you want a 12 second car if so then this is the turbo for you.as for boost it will be between 3500 -4000 but very liveable so you can drive in traffic off boost and when you nail it it will fly. don't stress about when boost comes on cause when you hit boost with this turbo 1 second later you will be looking for the next gear :mad:
btw you can run this turbo with stock injectors but just lower boost the stock injecotrs are good for 210-220 rwkw that might be enough for you.
just some ideas.
in my book this is one of the best suited turbo's for an rb25 and should keep you happy. but you need to ask yourself it that kind of power is what you want!
meggala
Thanks, meggala
Hi-flow the stock turbo was my initial idea, however after doing some research and went out to get the quo, I feel sell my stock one and get something else also seems to be a good idea, then this set comes up at very fxxk cheap price ( sorry, the price will offend some people).:eek:
What I plan to upgrade was first have a full set of exhause system, however this set comes up, and I know i will not have same set coming again soon, therefore i might get this turbo first then save some money for exhause system.
210/220kw :burnout: was not really at my target (don't dare to dream about..), but acceleration mainly is my conser....so, when you say keep the boost low, what exact is the boost you will suggest?
thanks once again, you did solve my question.
What exactly have you done to your car?...from my point of view it sounds like its stock at the moment correct?
Remember when upgrading a turbo you would need to upgrade everything else to cope with the new power its going to increase on your engine.
I would not touch a turbo unless your car is breathing properly, Full exhaust/Intercooler, Secondly you would need the fueling system to cope, Fuel pump / Injectors (depending on how far you wanna go)/ Fuel Pressure Regulator. After that you would need a ECU to tune everything correctly.
Not trying to sell you out here, if its a really good price buy it but dont install it is my advice, untill everything is fine.
I wouldnt run more then 1bar on that thing, 10psi as meg said if your just crusing around the streets, from what ive heard from people who had done this, said you start spooling around 3500-4000 rpm (if you dont mind the lag also) once turbo kicks in hold both steering wheel with 2 hands :mad:
Have fun with it mate, Best of luck
just remember if you let this bargin go away im here 2 grab it :P
Joe.
Thanks Joe and Mag.
It's stock, only have air pod and PowerFC.
I will not install the turbo, that's what i think atm, because this cheap turbo set won't come again, but the rest gears can buy at anytime.
I post a thread a while ago, regarding the FMIC ( see here ), can any one coming some suggestion? please!!
I am ring around for a 3.5" Full exhause system, but the dump pipe might have to modify to suit the turbo.
Z32 AFM and R33GTR fuel pump is in place , but still looking for 550 cc injector, but one thing not sure is "do I need a new fuel rail?" anyone recommand?
Clouch will be next issue, however my budget is a bit short after all these, i might wail until it slip.......(if by any chance)
of course, the turbo will sit in my garage for a while, until rest all up and ready, however if I get scare away by that sort of "both hand on steering" then it will on the market...will let you guys know..
cheers,
Joe.
Once youve got it would you mind telling us the price?
The only reason I ask is that I am putting the same setup on my 32. I got a HKS T04e for $400, a brand new turbosmart external wastegate for $470 and modified a stock manifold at a cost of $200. The turbo had a crap compressor whell so I got that changed and had the thing rebuit at a cost of $600. So mine has cost under $1700 and is new basically.
What is the exhaust A/R, and the whell sizes as these make a difference. Have a good look at the wastgate as these can rust and seize and this is not good.
You will need a new dump off the turbo as well as one off the wastegate. The only turbos that will fit the manifold are those with a T04 flange.
With you injectors you could make a new rail and use top feed injectors and I have also heard about people drilling them to bigger sizes, may be worth a look.
thats the same turbo as ive got on an RB20
im using a HKS external wastegate and its on HKS exhaust manifolds.
full boost is around 4000rpm so not TOO bad. it does come on boost fairly hard though!
im currently making 230rwhp in a very badly tuned state. thats with 12-13psi and a bosch 910 fuel pump
hopefully with a remap and 1 bar should be pushing the 200rwkw mark!!
if you can get it cheap and dont mind a bit of lag then yes its a good turbo. just make sure you sort out your management and fuel system as well, ive blown one engine already due to too much boost and not enough fuel!!!
good luck with the turbo/car!
adam
Thanks guys, will let you know the detail once all sort out.
Yes, just source a second habd 3.5" front to cat back (the canon style) at very reasonable price, well at least can use it for 2 month before pay for it...
For the dump pipe to work with the tubo, i should just wait and have it custimise made right? thanks.
Me thinks lag is pretty cool.
You can be driving Miss Daisy until your floor it then hold on. Personally I'd hold the steering wheel with one hand cause gear changes come pretty quick.
Car becomes Jekyl & Hyde. Can drive around not hitting boost, with no blow off valve noise to attract unwated attention. But you know it's there when you want it.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
