R33 Headlights questions
Hello all.
After a few minutes of search on the forum, I don't find some informations thath I need (or I don't used right keywords).
My questions are:
1: What are differences between R33 headlights spec1, spec2 and spec3? what differences? they are all compatible on all r33? or the mounts change?
2: For the Xenon and Hid Headlight, the headlight level is automatic or manual electronic? (if you have high load on the trunk, it corrects the level automatically?)
3: For the Xenon, someone has the dimensions? (like that: https://hidkitpros.com/wp-content/up...dimensions.jpg
Thanks a lot
Greetings from Switzerland
https://www.sau.com.au/forums/topic/469719-r33-headlights-questions/
Link doesn't work
Don't put HID kit in your halogen headlights. Don't put LED kit in, they're all shit.
Series 3 GT-R came with factory xenon/HID (bulbs starts with D, not H) http://www.kudosmotorsports.com/catalog/headlight-xenon-nissan-skyline-series-021997-p-534.html
See:
Make sure the (outer) headlight lenses are clear. Use a headlight restoration kit if they are hazy/yellow. Any hazing will reduce output. I think the R33 uses H1, so don't have much of an upgrade besides Osram nightbreakers/Philips x-treme vision. Make sure you aim them properly.
Not sure on the level adjustment, probably not auto/self levelling.
Do a retrofit! It isn't as hard as it seems. Your end result will be so much better.
7 hours ago, niZmO_Man said:
Link doesn't work
See:
Thanks a lot for all those infos.
My problem is that I have to convert my headlights to LHD, and if I want to stay with Xenon Headlights, they must have headlight washers and auto/self leveling ajdustement.
9 hours ago, niZmO_Man said:
How strict are they at checking cars when you drive around? You might be able to get away with a Morimoto Mini H1 (switch the bulb to halogen during inspection time).
90's Skylines are RHD so...
With this kit you can use full halogen or HID?
Some other questions, I could preserve the Xenon Headlights, but i can't exceed 2000Lumen.
Some one know how can I do that? What bulb use with stock Xenon headlights?
The morimoto mini h1 are direct replacement on the xenon headlight of R33?
They are really strict.
Or it is possible to have xenon or hid kit with maximum 2000lumens?
I saw that there is hella projectors with magnetic leveling. Maybe its ok but I cannot find that.
No not direct fit. Retrofitting is opening up your headlights and mounting projectors in there. Work can vary quite a lot (read: lots of effort), especially on reflector headlights.
I think you should forgot about those cheap HID kits and focus on improving your current setup. Clear front lenses plus bulbs like the Philips X-treme vision.
OE series 3 GT-R is D2S I believe.
I think you'd be after the 25W D5S/D6S/D7S/D8S, which are supposed to be 2,000lm and not require self levelling/washers.
The point I'm making is, the H1 reflectors are designed for H1 bulb as light source, no benefits gained from throw in anything besides H1 bulbs, if you're after actual performance upgrade. Retrofit projectors from an Audi or something with the 25W HID projectors, or LED projectors from something like Prius V.
Nice info mate.
Opening the headlight it's not a problem.
I can replace the d2s with the d5s directly?
I would rather prefer having projectors that reflectors, because it's easy to convert to lhd pattern.
Led projectors? Sounds nice. Do you have other infos about that?
Yeah, replacing projectors isn't a big thing, usually easier than working with reflectors. I have no idea what sizes/shapes the D5/6/7/8 projectors come in, too new for me :P.
LED projectors are another thing you can try, if you can find. I recommend the Koito bi-LED, such as found in Prius V, and other cars like Murano. You'd have to look at wreckers/junk yards and second hand parts places like that. With LED you can usually wire them up easily and not worry about bulbs.
I actually have a bunch coming from Japan, so will see how they go in R32 headlights :D
I'd probably be easier to find 25W HID projectors and fit them into your current headlights. This will require lots of work so I recommend getting a second pair of headlights (doesn't have to be Series 3 HID ones).
But yeah, let us know what you find.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
