Since I've imported my R33 coupe it's had a very slow leak which looks like it's coming from the internal seal of the RH tail light inside the boot.
A slow dribble around the seal.
Problemo is I can't seem to get the light out to re-seal it back in.
The little bugger is stuck, my mechanic even tried heat lights to soften the black gooey sealant to no avail.
Was considering cutting it out with a knife but scared of breaking it.
Are there any secrets to removing these puppies without breaking the tail light?
Just don't want water/ rust to start inside my boot when it rains heavy.
https://www.sau.com.au/forums/topic/469822-leaking-rear-tail-light-r33/
I did this maintenance about 5 years ago. From memory the whole tail light unit unbolts and pulls out, so no need for cutting anything while on the car. Then the real fun begins of heating and prising apart the 2 halves, scraping the old seal off and applying the new sealant, either genuine Nissan stuff or you could probably use some kind of silicon sealant. Then refit
Just silicon over it.
I also had trouble getting it out back in the day and just yolo'd it and whacked silicone all around the seam and black stuff.
But the reason your tail light fills up is because the factory putty stuff in the water channel seam of the boot is deteriorated and letting water run down there.
Chisel out and reseal
Definately can't get the thing out even after unscrewing it. Its fixed in pretty tight.
It leaks through where the black sealant already is.
I'll checkout the boot channel seam area and see if that putty stuff has deteriorated.
Ive got a spare pair of blue tail lights as a worse case scenario. Its mainly the LP2 trim thats the issue if stuff breaks. Not the easiest colour to source when buying spare parts.
Cheers
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
