RB26 Cam and Timing Gear Covers
RB26 Cam Covers and Timing Gear Covers in good condition (no valley cover).
These have removable baffles, which can be upgraded with Mines or High Octane parts. I have removed these to clean them, came up looking good. Great upgrade over 20/25 covers, unpainted and still have the standard breather fittings. Intended to use them on my 32 but sold the car.
Located in Brisbane, happy to post or courier at buyers expense. Local pick up preferred.
$550 negotiable
  • Like 1
Work VSXX 18x9.5 and 18x10.5
Work VSXX 18x9.5 +12 and 18x10.5 +18 - 5x114.3.
- Set of freshly reconditioned wheels Powdercoated Gloss Black lips and Matte Black centres by Roberto's Custome powder in Brisbane.
- Brand new Centre Caps, Genuine Work gold bolts and Valves from JDM Concept.
- Assembled and sealed by Dr Wheels in Yatla.
These amazing wheels have not yet been driven on or had tyres fitted since being rebuilt. I no longer own the car they were intended for. These would be amazing for s14/5, R32/3/4, 350z. Are def going to be aggressive fitment on standard body.
Can courier at buyers expense.
$3,500ono
image.thumb.jpeg.7592ec139b14173ef6efc1da98408ae3.jpegimage.thumb.jpeg.eff808b8099b3183ef23e2fecc36f15b.jpegimage.thumb.jpeg.127b3ca258111f8e6abeb1c77ae16120.jpeg
  • Like 1
Thank you Birds. If any mods read this could someone please correct the thread title as it's just the wheels for sale now.
Bump wheels $3000ono Keen to sell these, but not entertaining low offers.
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
