R32 gtr knock sensor loom, discontinued part from nissan, new $150 SOLD
WHATS LEFT with price drops
GTR
R33 gtr complete cold side, inlet manifold, throttle bodies, plenum etc $400
R32 under bonnet mat, used good condition $50
R32 gtr ecu $100
R32/33 gtr coil pack ornament $100
R32/33 gtr exhaust manifolds $100
R33 gtr oem dump pipes $25
R33 gtr oem turbos $100
R32/33 gtr turbo inlet pipes, the cast alloy ones $50
R33 gtr oem front diff $100
R32/33 gtr fuel rail $50
R32/33 gtr tps $50
R32/33/34 afm's $100
R32/33 gtr CAS $100
R32/33 gtr coil pack set $100
R33 gtr alternator $100
R33 gtr coil pack loom, $25
R33 gtr balancer, $50
RB26 N1 block new, $4995
R34 GTR
Oem intercooler $200
Oem bov's and all piping $200
All intercooler hoses $50
R32 GTST
Boot lining 4 pieces inc carpet $150
Boot lid $100
Type M rear spoiler $100
Type M brake calipers, front and rear $300
MISC
HKS super hybrid panel air filter, less than 200km use, suits all rb air boxes, as new $20
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
