  • Replies 97
Originally posted by [ryan]
What's news Brendan - have you got the car back yet? How did the modifications go?
Slowly but surely - Will have news next week. As for 450HP ...... maybe a bit optimistic now I know a bit more. The mods would make the car 450 HP capable, but with standard internals and the boost needed to get to 450, the donk woudn't last long - So 17-18 PSI is the max I will run it at. Can go up to 22-23 but...
Stay tuned,,
Hey ppl,
Put the car on the Dyno today for an initial tune. Dowloaded a EMS map from a similar car as a start - Results look promising. Stilll a bit of work to go tho.
Run 14 PSI with crappy cat ( the hi flow one will be available in 2 weeks)
Got up to 220rwkw.
With more EMS tuning, Hi Flow Cat and more boost (18PSI) should hit the 260rwkw mark. I'll be happy with that. There's a few more things to do to....
It's a totally different car to drive - The turbo makes an awsome sound when spooling - Boost comes on at 2300 RPM. Def need new rear tyres & new clutch soon...
Also, am running the turbo in, so no silly boost or anything. I'll go back in a week or so, give my report from driving her around for a bit, put the cat in, wind up the boost and see what she pulls then.....
More to come...
PS Freakin Turbosmart Supersonic BOV is one loud Mutha Farka - anyone knwo how to turn down the volume on one of those babys ?? Shoulda got a plumb back jobie.
Hahaha i got the same BOV as u, im pretty sure. its bloody loud! I dont think you can turn it down and why would you want to? The louder the better!!!:uh-huh: :uh-huh:
So what are these HKS SS Turbines?
What do you exactly mean by that?
I thought a T3/4 Hybrid was using your origional T3 Housing with a different compressor housing T4.
HKS SS Exhaust housing?!?!? I've never actually heard of an SS Housing.
Ended up using a GCG Hi Flowed R34 Turbo - new performance bb core and upgraded (steel) compressor and turbine wheels. Rated at 500HP.
Yeah - I think so - the 500. Mark from Hills took care of all of that for me - I know he had to send it back once to get a 1 bar wastgate put on it.
Re; full boost- I haven't paid that much notice to be honest, it gets there so quick now, I'm watching the road mostly, not the boost guage. Let me drive it round a bit more and I'll let you know. I do know that boost starts just after 2000 RPM - The tubine spinning up sounds awsome.
The clutch is usually the first thing to go when you give it more power, mine only lasted 3 days when I increased the power, hopefully my twin-plate should go the distance.
Go for something stronger than you think you'll need cause the clutch always takes a hammering.
See'ya:burnout:
I went the xclutch 9 button ceramic ferride sprung clutch with 2500 lb pressure plate. I would have gone a twin plate if I had the time and dollars to source one. I need mine as a daily driver to from work, and was scared the clutch wasnt going to get me to work, so I stretched the budget just enough to get this done. Damn shame there wasnt a second hand twin plate handy at the time, as I can see this one protesting in the not too distant future- fingers crossed.
Yes I know a few people who went the same path, and while they are a good clutch I do not think they will hold up under the punishment of 300+rwhp. They are however very easy to drive, but my twin plate only took a couple of days of getting used to. Although second-hand twin-plates are becoming more common they are quickly snapped up, due to most people frying the factory one.
See'ya:burnout:
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
