Originally posted by GTS-t VSPEC
Yes I know a few people who went the same path, and while they are a good clutch I do not think they will hold up under the punishment of 300+rwhp. They are however very easy to drive, but my twin plate only took a couple of days of getting used to. Although second-hand twin-plates are becoming more common they are quickly snapped up, due to most people frying the factory one.
See'ya:burnout:
a bit off the topic..for those second clutch, normally only some % left, can they be re-condition? or rebuilt? Looking for one NISMO and OS clutch..thanks.
  • Replies 97
Yes the name brand clutches can be rebuilt, we have had it done to a number of clutches including OS Giken and Nismo. They come out feeling like brand new, and will often save you a bit of money over buying a new clutch.
See'ya:burnout:
Many of the multi plate clutches can be rebuilt but they are not cheap to get done. Would only be worth buying something cheap.
I thing extreme are starting to make their own twin/tripple plate clutches as well, a lot cheaper than imported stuff.
It is good that some Australian companies are starting to provide performance parts in competition to the Japs, lets hope they make a good tough clutch for the skylines.
See'ya:burnout:
Totally agree, the Japs do what they do well, there is no doubting that, but I do believe that australia can do as well or better, and they regularly do.
...only that it still costs the same price.
In some cases yes, but in others no. I got an aussie made coola, 2PSI drop at 650hp cost $800. Also $400 for a custom built dump and front pipe, hand finished and blemish free (have you ever had a good look inside a HKS one?)
Besides, I know where I would sooner spend my money - in Austalia.
IMHO
Steve,
I totally agree with you, aslong as the product is as good then I want to spend my money in Aus. I think the market here is starting to catch on to the growing demand for performance parts, with many Australian parts now being used overseas aswell.
I don't see the point of spending twice the amount of money on exactly the same product just cause one is a Jap brand, compare them on performance/reliability.
See'ya :burnout:
See'ya:burnout:
I agree completely - which is one reason I chose EMS for my ECU (plus is heaps more flexible than others). Also , I decided today to get a Australian Manufactured 6 puck clutch - should be as good or better than a Nismo or OSG one, and half the cost (installed). Actually when I come to think of it, out of all my mods, I didn't buy one new Jap branded part.
Cat = USA
Dump & Front = Aussie
Turbo = Aussie re-engineered (Org Jap)
Injectors = Aussie re-engineered
ECU = Aussie
Plenum = Aussie Custom
Surge = Aussie Custom
Fuel Pump = Bosche (German right)
Catch Can = Aussie Custom
Clutch = Aussie
brendanf,
Once you have had some time with the clutch then let us know what you think of it. It will be good to have a list of Aussie manufacturers that can compete with the Japs.
I tend to get alot of my stuff custom made here, the workmanship is very good and generally much cheaper.
See'ya:burnout:
  • 4 months later...
Clutch is good - quite happy with it - shudders a bit when you take off up a hill, but I understand this is normal because of the grip of the pucks & kevlar.
Re Mods: I didn't get to try them out to full potential before the motor lost compression in two cylinders. (Don't know why yet cause the head hasn't come off yet) Suffice to say that the compression is so bad (60) that we all know what is the problem -What caused this could be a number of things, as we all know.
Right now the car is in my Garage, waiting for me to save up for a full re-build with forgies, strengthend rods/bolts, o'ringed/dipped block, the best bearings I can get, maybe some head work, maybe a metal (or composite) head gasket and definitely cams - AIM = 300rwkw (reliable, safe, strong, bulletproof kilowatts)
When the engine is out, I'll be getting the injectors tested/flowed cause what happened, shouldn't have (in my opinion) - I was only running 14PSI at time failure.
So ATM I am reading lots and lots about what others have done and are doing in terms of engine rebuilds - Also happy to take suggestions/recomendations from the forum on what I should/shouldn't do to attain my bulletproof 300rwkw. The only other mods I had done since this thread is a 1:1.5 adjustable fuel pressure regulator.
Cheers,
Thanks Tony, Your 100% right - I was devesated when the engine went - esp after spending a lot of time & $$ on it and not actually getting to enjoy it at the track - Plus, so soon after the mods - (I even tried to sell it as is, I was sooo pissed off) But I'm over it now, and am looking on the positive side.
1) Will have more reliable power after the next stage
2) Have plenty of time to research all the right moves
Thanks to everyone for the help so far - there is more to come ...... I even changed my avatar to refelct my new found enthusiasm.... he he :D
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
