Hi Guys!
Time for another cruise!
Date: Sunday the 9th of July
Meet Location: KFC - The Crossroads Casula (Corner of Beech Road and Parkers Farm Place)
Meet Time: Meet at 9:30am for a 10:00am departure
Destination: Robertson Pie Shop
Map: https://www.google.com.au/maps/dir/KFC,+Cnr+Beech+And+Parkers+Farm+Rd,+Casula+NSW+2170,+Australia/Robertson+Pie+Shop,+4400+Illawarra+Highway,+Robertson+NSW+2577/@-34.2521388,151.2108135,10z/data=!4m29!4m28!1m20!1m1!1s0x6b1294b79d01f8f5:0x15d544593a6d593!2m2!1d150.882024!2d-33.959479!3m4!1m2!1d150.8832225!2d-33.9608526!3s0x6b1294b7c574d11b:0x13017d67e5b388b0!3m4!1m2!1d150.8815662!2d-33.9593794!3s0x6b1294b79c6c5c23:0x229744872340fd8b!3m4!1m2!1d150.6994763!2d-34.2455556!3s0x6b13027146e91a0f:0x130609b4730cdd91!1m5!1m1!1s0x6b1375025c520b8d:0x938cd27970c7bd74!2m2!1d150.626297!2d-34.585871!3e0?hl=en
We will meet at KFC at the Crossroads and from here head onto the Hume Highway.
From this we will turn off onto Picton Road and follow this all the way into the Prices Motorway eventually reaching Albion Park.
The meet location is in front of St Paul's Catholic Primary School, Tongarra Road at around 11:00am - 11:30am.
Here we can make a quick rest stop to stretch our legs and allow everyone to catch up before heading off through Macquarie Pass.
If any lower west members would like to come this would be a good meet point.
From this it is a short trip up to Robertson Pie Shop for some of their famous pies and deserts.
There will be a lead and follow car so no one should get lost.
We will also be bringing along walkie talkies to keep the group together so if you have one please bring it along.
If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior!
This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days.
This is an official SAU:NSW event and will be run under a CAMS permit.
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
• Be aware of surrounding environment and act accordingly.
• Drive courteously on the state’s roads as a true enthusiast should.
• Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly.
• Any misbehaviour will not be tolerated and you will be asked to leave.
Thanks guys and hope to see you there!
  • Like 2
Attendees:
1. Aussie_Delivered_R32_GTR
2. twotwisted +1
3. GTR-N1 +1
4. sammi_d
5. ozzydee +2
6. pureplaya
7. AH33 +1
8. Yo-Yo +1
9. 300CHONG
10. niZmO_Man
11. gts25 +4
12. crashdown
13. Micah_ +1
14.
15.
16.
17.
18.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
