Advice / Input
Hey Guys i'm new to the forum and need some help if you don't mind.:banana: I live in South Africa
I currently have an Rb 25 Det lemme give quick run down on spec's.
Sub Assembly skimmed 1 mm Rb 26 pistons 86 mm COMETIC Head Gasket
Head done ported and gas flowed cams cut 270. Done by Steve Clark No Sweat Racing
Head currently has all Rb 26 parts , Valves , Quarters , Retainers , Valve Springs , Lifters etc. So Head is Solid Cams and Lifters. Head can probably rev about 8500rpm+ but oil pump is stock.
Branch build by Marius from Full Boost 3 into 2 into 1.
Turbo Garret 60-1 T4
Bosch 750 cc Injectors
Bosch 044 external and Facet in tank pump
Rb 30 Clutch and Pressure Plate
40 mm Wastegate
Custom Intake Manifold
Intercooler
Spitronics Engine Management 60-2
70 mm Exhaust
Currently has 1 Bar map on 95 ctane pump fuel. Took the car for Dyno but was spark breaking on the Dyno will replace this weekend.
Not sure if any of you have similar set ups. So this is where I need some info please car will be going back to Dyno soon:happy:
I will be Changing Fuel to 50/50 95/Ethanol
What do you guys thinjk Rb 26 pistons can take max boost?
I'm looking to try and push for 1.2-1.5 bar boost is this ok?
What Hp should I aim for safely?
If you guys can assist with any input will be highly appreciated. Sorry about the book tried to give as much info as I can:cool:
Thanks
Brian
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/
Hi thanks man. It is a 1972 Chevrolet 4.1 Limited manufactured in SA and Australia also had them.
Awesome, I'm not a huge muscle car guy so would never have managed to guess. I hope someone here can give you some guidance. :)
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836682
Thanks and I hope they will assist me. Unfortunately had to do mod in there because they never brought R32,33,34 to SA. We can only buy the engine's here or import the car which is very expensive. I would like to own a R34 Gtr Vspec though:banana::banana:
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836684
1.5 bar is nothing - do not go by numbers - your tuner should keep increasing boost until it becomes counter productive and similarly tune to max with regard to exhaust temps knock control etc. You will get what you get.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7837240
Hi Kiwi I've been busy with converting a set of coils but came across another thread discussing some of the issues other guys are having. After reading through It seems to me that I may have a similar problem. So I removed all the coils including the aluminum portion that is bolted in the middle of the cylinder head. Low and behold the hole bottom of the aluminum casing is black seems that the coils have been earthing against it when ever it spark breaks. So my car starts normal idles normal and rev up to limit when stationery also is not missing like a dead plug or coil. Only time it spark breaks it under load. So I got some liquid electrical tape with a brush and also bought some plastidip spray also for electrical insulation. I will be spraying the aluminum cover with that to insulate it so the coils does not spark against it. Also will do the coils and suppressors with the other. Worth the try I guess. I unfortunately cannot have the aluminum portion cnc'd out of plastic as the other guys did. So I will be doing that tonight possibly with put everything back tomorrow and go and test. Hopefully resolves my issue if not I have been busy with a set of other coils. Don't know if you've seen any of the threads speaking about spark break issues.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838250
Yes there are hundreds of such threads. Your fix may work for a while (gap your plugs down to 0.8mm as well) but start saving for some new coils.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838265
