NM35 VQ25DET Camshaft Rattle Post Senor Replacement
Hi All
Just replaced the 2 camshaft position sensors on my old mans NM35 Stage (VQ25DET) and now the car is getting a rattle at circa 2000RPM from what appears to be the camshafts. I have read that this can be caused by using oil that is too thin, or the spring return within the variable cam timing assembly failing.
Prior to going down the path of the variable cam timing assembly, we will be trying an oil change but was also curious if maybe the replacement of the camshaft sensors requires a camshaft re-learn procedure and is there anyway to do this without a Consult 3?
Any assistance is greatly appreciated.
It's more a clunking sound than a rattle to be honest and happens randomly above circa 2000RPM. Car is running 10-40. From what I can recall, this has only come about post replacement of the sensors.
Engine performance still feels strong and there is no loss of performance from what I can gather.
If its a single clunk its going to be the cam advance.
If its a repeated clunk clunk then its going to be the mechanism.
I have changed my intake timing to advance earlier so i hear it when i put my foot down basically from idle it is quite loud and would sound like something is wrong id you didnt know what it was.
Just a quick update. I replaced the oil and for the first quick little drive the clunk didn't happen. Once the car warmed up, the clunk came back.
I then disconnected the passenger side blue cam plug and the clunk disappeared.
I am assuming that with the VCT not active (both blue cam plugs disconnected) there is no issue running the car ad there is just less power as the cams haven't been advanced. Thoughts?
Is the cam mechanism removal an engine out type job?
Edited by stealth01
Its fine and normal. If its the noise Im talking about,
The cams dont seem to advance initially when cold (i have found from my logs showing 0 degree across the whole rev range when first starting up).
I can try and record mine for you it sounds like a clunk almost like slack in a centrebearing noise.
When you disconnect the solenoid you are not activating the advance.  thats why it goes away.
Edited by m35stagea
The sound is something new and one that we haven't heard before. Doesn't sound like it would occur in normal operation given the nature of the loud clunks.
Has anyone tried the replacement of the VCT Cam and is it an engine out type job or is there enough room in the front of the engine to remove this when taking off the front engine cover?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
