Safe boost levels for -9 Equipped R34 GT-R
Hey guys,
I recently purchased a pair of GT2859R -9 turbos due to the stock ones having blade damage and needing a full rebuild. I was wondering since the new turbos provide more flow, what boost levels would be considered to be 'safe' on a completely stock RB26? I previously ran 1.00 bar on the stock turbos and the car seemed to run fine although I did notice the injector usage getting close and hitting 100% which makes me slightly concerned for the new turbos. Do you think the stock boost of 0.8 bar would be fine or possibly even less?
Cheers, Nick.
Edited by NAB 8
Changing format
Compressor map shows 22-psi is about max efficiency.
https://turbochargerspecs.blogspot.com.au/2011/03/garrett-gt28r-gt2859r-56-trim-310-hp.html
Approx 2.5 Pressure ratio on the graph.
HOWEVER, people argue that the limiting factor to the turbo's longevity is actually the turbine flow/heat and as you can see from the graph, the turbine starts to choke before the compressor does. Choke = heat, heat = premature wear etc.
So how hard you run them depends on the type of usage and your appetite for risk.
20psi should be fairly "safe" on both fronts, but 22-24psi squirts are not going to hurt a healthy turbo in a street application.
Other variables come into play here also, fuel type use? E85 has lower EGTs = happier turbo. Size of dumps and exhaust? Bigger = more flow, less backpressure and less work for the turbo. Etc etc.
We ran out of fuel pressure on the dyno at 373kw at 20psi on -9s in my car so this week we should see if it will happily hold 20-22psi. Keep in mind this is with N1 manifolds, 3" dumps into 3.5" exhaust, E85 and Kelford L182A cams (springs and head studs for insurance) with pods (proven to make more power at this boost on the dyno) and a Plazmaman intercooler.
To run 20psi+ on these turbos you will also need fuel pump, injectors, an ECU to make use of it all, and quite likely AFMs if you stick with those rather than going MAP (which would also mean needing a MAP sensor).
  • Like 2
Cheers for the quick reply Dan, I appreciate the effort too. Yeah I plan on getting injectors, ECU and a fuel pump later down the line but I will definitely keep this in mind :). In regards to running the -9 turbos on my current stock setup (stock injectors, pump etc), should running 0.8 bar be safe in terms of fitting within the stock injector's/pump's limits? even though it seems as if they were maxing out on the old stock turbos?
Remember PSI is just a pressure reading in the manifold and tells you nothing about the actual air flow being put out by the turbo/ingested by the engine.
For safety sake, you will want to put it in a dyno at a bare minimum and not be getting into boost until you do.
Make sure the AFRs are safe. As -9s are a step up in size compared to stock, they flow characteristics are quite different.
Usually, people do turbos with an ECU/injectors/pump etc as you can't make good use of the turbos otherwise.
Are the current turbos actually stuffed? Minor chips in blades is not a big eal at low boost and could allow you to get the other bits together and do it all at once properly.
Yeah the old ones are pretty far gone :/. I might just install the -9s then and keep the car off the road for a little longer until I can get injectors, ecu etc. Thank you for you help though :)
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
