hey guys,
i have some stuff for sale:
apexi safc II D1 limited edition - $460
hks ssqv bov, $360
apexi turbo timers (pen shape) - $150
apexi boost gauge - $180 (1 black face and 1 white face)
all items are brand new.
shipping is $5 and anything over ill pay
https://www.sau.com.au/forums/topic/47109-fs-hks-and-apexi-parts/
