FS [SYD]: Splitfire Coilpacks w/ Box | Coilpack harness | Coilpack bracket & bolts
Hey Girls and Guys!
So you may know or probably not know - I bought a NEO motor. This means majority of my R33 RB25DET stuff is pretty much useless on this motor.
I have a wonderful load of items for sale for such a lucky person! No more misfires, no more coloured coilpacks that aren't blue dropping out and causing ECU outputs to short circuit or ECUs to shut down. These are the real deal, no bullshit Splitfire SF-DIS-005 Coilpacks!
You're thinking, this guy actually kept the original box? yeah I sure did! I always wanted to sell them and convert to Yaris coilpacks one day, but that "one day" turned out to be 4 years! Anyhow, enough random bullshit this is the break down:
  • $300 - Splitfire Coilpacks with the original packaging
  • $50 - OEM Nissan quality coilpack harness, no cracked clips!
  • $50 OEM Nissan quality coilpack harness for RB25DET motors (long live the VCT!)
Because I am Asian, there will always be a best pry cash deal. I do speshcal pry, $350 you tek de lot - kesh only.
Price: $350 the lot
Fitment: ECR33 S1.5/2 (no ignitor pack) and BNR34
I will only post if you direct deposit - no PayPal because there are too many dodgy scammers out there. Pick up > Post.
5 hours ago, john boost said:
Hey mate would you sell the coil pack harness seperate?
Sure will!
OEM coil pack harness no longer for sale. Turns out the R34 NEO and R33 will work however the plug lengths are incorrect as the coil orientation is different. Schematically the harnesses are identical.
Now for sale is my Wiring Specialties R33 RB25DET S2 coil pack harness. This is about 1.5 - 2 years old or so.
$100
I said you could borrow it before lolol..
I thought I could use them on the NEO head but it doesn't fit :(
Coils are sold
Coil brackets are sold
Still left, Wiring Specialties Coil pack harness.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
