Gauge cluster problems
Hello everyone I'm new to the skyline community, just got my r32 gtst last week been having some problems and with limited time and resources could use a helping hand.
So my problem. Right now is all my gauges do not work except for boost gauge and oil pressure but I suspect the oil pressure gauge is also broken. When the car starts the oil pressure starts off low then drops to zero after a couple minutes as there is no awful noise coming from the engine I assume the gauge isn't functioning properly the fuses and such are  labeled in Japanese for the most part so I'm having trouble with that and locating various sensors thank you in advance for the advice.
https://www.sau.com.au/forums/topic/471873-gauge-cluster-problems/
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
