EnricoPalazzo Posted July 27, 2004 Share Posted July 27, 2004 Hey Guys, ive organised some sweet prices on a set of 6 x 540cc injectors which are straight fit into the rb25det fuel rail. These injectors are high impedence, side feed and same size as stock, so no problems in fitting. They are manufactured by Hitachi Unisia Jecs(same manufacturer for Original injectors for many Subaru cars, STi, Nissan, Nismo, Apexi, HKS, Power enterprise..etc) The clips are slightly different, and either can be modified quite easily ive been told to fit into our plugs, or we can purchase correct plugs from mitsu electric. These are ultra atomization technology injectors that assure the very fine atomization of fuel, making your idle stable and providing impressive fuel efficiency. The injectors flow: 470cc/min at 38psi (standard fuel pressure) 500cc/min at 45psi 540cc/min at 52psi 575cc/min at 60psi What this means is that to get the correct cc out of them, you will also need an adjustable fuel pressure regulator, but I have been assured the injectors are designed to run this amount of pressure, so they will be fine. Retail Price on these are $1060 for 6. If i can organise 10 sets, then the price is $520 = postage ($10 approx?) So comon guys, this is our chance of gettin injectors finally cheap. Excellent quality injectors made by the same companies as the more expensive ones. The List of interested people: EnricoPalazzo Shane JaFF GIGOLO bigcarl rb25 Muz Al Trust33 Sciby myr332 Lepperfish TonyGTSt Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/ Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 If anyone needs more info, PM me. this group buy starts today, and depending on numbers, will end 1 month from now, being FRIDAY AUGUST 27. SO GET IN QUICK! Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-954825 Share on other sites More sharing options...
Anquetil Posted July 27, 2004 Share Posted July 27, 2004 I'm keen, I should be able to scrounge up the money by that date. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-954832 Share on other sites More sharing options...
Al Posted July 27, 2004 Share Posted July 27, 2004 How much are the clips and do they fit the std fuel rail/plugs? Sounds pretty good though. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-954860 Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 the only thing that ive been told needs modifyin is our plugs that fit into injector clips. I will find out more info. Everythin else fits 100% like standard. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-954956 Share on other sites More sharing options...
Muz Posted July 27, 2004 Share Posted July 27, 2004 I'm interested but will await the info on the plugs before giving a final. Great Price BTW Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955037 Share on other sites More sharing options...
Blade Posted July 27, 2004 Share Posted July 27, 2004 Me to im interested...been searching around for a decent set at a decent price for a long time...that date also gives me lots of time to easily get the $$$ but like muz said await the info on the plugs Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955094 Share on other sites More sharing options...
rb25 Posted July 27, 2004 Share Posted July 27, 2004 :werd: Put me on the list pending numbers and modifications required to the plugs. -rb25 Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955134 Share on other sites More sharing options...
Bass Junky Posted July 27, 2004 Share Posted July 27, 2004 How much power will these flow? Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955136 Share on other sites More sharing options...
knore Posted July 27, 2004 Share Posted July 27, 2004 540cc should be good for approx 500hp Thats an awesome price! Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955177 Share on other sites More sharing options...
bigcarl Posted July 27, 2004 Share Posted July 27, 2004 if we can get hold of the clips coumt me in for shore!!! Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955207 Share on other sites More sharing options...
GIGOLO Posted July 27, 2004 Share Posted July 27, 2004 Im interested, how much will they flow with the std fuel pressure? Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955261 Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 Ill find out all the above questions, but it would be worthwile gettin a fuelpressure reg aswell to maximise the injectors capabilites as they are designed to run higher pressure. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955269 Share on other sites More sharing options...
GIGOLO Posted July 27, 2004 Share Posted July 27, 2004 I'm only planning on running 260rwkw and don't think I'll need the extra 40cc per injector. Will it cause any problems running the std fuel pressure? Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955277 Share on other sites More sharing options...
mokompri Posted July 27, 2004 Share Posted July 27, 2004 those injectors look damn familiar... is there a stock US market subaru that comes with these ? ive seen them around ... i'll post up tonite which model it is, im sure ive seen these on ebay being listed as side feed, although i wasnt sure of the resistance, and they looked exactly the same with same colour very good price though i'll dig up some more info on it and list what subaru motor it comes on Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955290 Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 no probs running stock fuel pressure thru them. mokompri, i think we saw the same ebayer selling these injectors. this is how i contacted him thru ebay and this is how i got a good price. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955308 Share on other sites More sharing options...
JaFF Posted July 27, 2004 Share Posted July 27, 2004 interested if all fittings are sorted. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955473 Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 To all those wondering, These injectors will flow 470cc at 38psi which is standard r33 fuel pressure. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955739 Share on other sites More sharing options...
EnricoPalazzo Posted July 27, 2004 Author Share Posted July 27, 2004 i got this email in regards to plugs: The actual connector can be bought brand new. (I am actually contacting and see how much they are.) It's probably better to go that way anyhow. I just wanted to tell you. The connector is Sumitomo Denso's MT6189-0056 is the type. It might be easy to buy it there, too, but I am sure it's better price here. I will let you know asap when I know. Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955759 Share on other sites More sharing options...
ImpulR33R Posted July 27, 2004 Share Posted July 27, 2004 maybe interested will let you know later in the month. thanks Link to comment https://www.sau.com.au/forums/topic/47226-540cc-injectors-straight-fit-for-rb25det-520/#findComment-955783 Share on other sites More sharing options...
