  • Replies 71
Its only the tuneability that im worried about.The z32 has nothing to do with the injectors i know.
I have been led to belive it is a better quality solenoid in the z32 that gives more accurate readouts.
But what im really trying to say is.Is it worth the money when tuning with a pfc,i was told that most stand alone units i.e.A pfc dont really need it because they can create theyre own fuel/ignition maps.
But in the end it is up to me for what i want to use to tune my car with.:rofl:
I prolly will end up getting one in the end.:(
Correctomundo!
People with stock ECU and even S-AFC should tread carefully.
It works but it won't work as good as people make it out to be.
Fully programmable ECU is what you need.
Once you go 550cc/AFM, it's time to think ECU.
T.
Tony, what's the go with the S-AFC? Is it truly horrible at controlling the injectors, or is it because it's fooling the stock computer into playing well with the larger 'jectors, as opposed to an AM ECU that can knows about the larger injectors from the outset?
It's a signal bender like the E-Manage.
It doesn't have full control of the motor unlike say an FC.
If I was to use one word to describe why an FC is better, it'd be "fine-tuning".
eg. you'll find it very hard to get the car anywhere near EPA with an S-AFC while the FC will make a better fist of it.
Saying that, I've seen the S-AFC control a car with a Z32, AFM and Trust internal gate turbo - just with horrible fuel use, emissions and performance was ok but a bit rough in delivery.
The FC cleared that up.
eg. there's a drop down menu for VG30 AFM and the injector size, plug and play as it were.
T.
Great price for the injectors.....would love to say "im in" as i need them, there the only thing left holding me back at the moment.....but wallet says otherwise for a couple more months......doh'
if I was in, would definatly like to know more info about the clips, as i'd be installing them myself too.....how to modify? or how to replace with correct clips....
Im still waitin, and im not too impressed about his time to replies, however my email has really bee screwed lately, so im giving him the benefit of the doubt...
Ill post as soon as i know the answer about clips.
I know mate, dont worry i wont go ahead unless im 100% confident. In the end it would come down to me if somethin bad happened, and i definately wouldnt want that. Like i said, my email is ghey, so ill send him another email with my other account, and hope it goes well.
Well i have not heard from the guy for about 2 weeks so i am very skeptical now... I even emailed him from numerous accounts. I dont feel safe anymore about giving this guy my money or anyone elses. sorry Guys i think this group buy is dead :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
