Having some dramas, my partner's S1 RS4V lost its brake lights yesterday. High mount, sides and centre all dead. Park/Tail/reverse lights fine.
Stuff I've checked:
-There's no voltage at the pedal switch
-Brake light fuse intact, swapped with spare, no change, measured no voltage at fuse.
-Globes fine.
I'm tearing my remaining hair out, and I have about 24 hours in which to get it sorted.
The ATTESA pump is also priming abnormally long and intermittently chucking the 4WD light. Both things have happened inside a couple of days so I feel there may be a connection.
Solved issue.
Someone had tapped the 12v feed and it had partly fried, this in turn caused the pedal switch to fail. Ran new wires and replaced switch.
Worth checking. I have a D21, had a look at it, someone had tapped the same wire on it for some long removed device, aaaaand the same on my HR31! Luckily they'd been done a bit better.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
