Hi everyone,
Apologies for my first post being a sale.
Selling my 1995 Series 1.5 R33 GTS-t
Located in Canberra
Price: $23,000 - open to reasonable offers
Currently serviced and tuned by Autotech in Hume. I've owned the car since December 2014 but I need something a little bit more practical. It's never been tracked, only used as a part-time daily driver and weekend cruiser. Car has a fully engineered RB25/30 with slightly under 30,000km's on it ( engineering paperwork will be supplied to the buyer). Currently makes 425rwkw on United E85 @25psi. Car has a flex-fuel sensor and can run any combination of E85/98. Car also has a boost controller so you can run either 14psi (wastegate pressure) or 25psi (car makes 323rwkw on 98 @14psi).
The body of the car has done approximately 161,000kms and is in great condition for a car that is 22 years old. Car is clean, always garaged, washed every week and is serviced regularly, with only a couple of minor imperfections (including a small stone chip on the front bumper that was on the car when I purchased it in 2014). The inside of the car is clean and in good condition. Pictures of the car can be found at https://www.carsales.com.au/private/details/Nissan-Skyline-1995/SSE-AD-4709888/?Cr=0
Modifications are as follows:
RB25 head (ported and polished)
Greddy intake manifold
Camtech 274deg camshafts
Tomei adjustable cam gears
Tomei solid lifters
Performance heavy duty valve springs
Spitfire coilpacks
ARP Head Studs
RB30 block
CP forged pistons
Nitto H-beam conrods
Ross harmonic balancer
ARP Main Studs
Garret GT3582R
6Boost steampipe top mount manifold
Turbosmart pro gate 60mm wastegate (plumbed in) with 14psi spring
Turbosmart Plumback blow off valve
Hypertune 90mm throttlebody
Front-mount intercooler with custom piping
3inch turbo-back high-flow exhaust
Magnaflow dual tip rear muffler
Walbro 460lph in-tank fuel pump
Custom made surge tank (under car)
2x Bosch 044 fuel pumps (under car)
Turbosmart adjustable fuel pressure regulator with gauge
GReddy dual feed fuel rail
ID1300cc fuel injectors
Braided lines throughout
Haltech Platinum Pro ECU
Haltech flex-fuel sensor
Haltech I/O Expander Box
3 bar map sensor
O2 wideband sensor
Mongoose 3-point car immobiliser and alarm
Rebuilt standard gearbox
Mantic custom built twin-plate clutch
Lightened flywheel
Short shifter
Bilstein shocks (adjustable)
King springs
Whiteline adjustable sway bars
Full front and rear suspension rebush
Hicas lockout bar
Rays Volk GT-7's (originally chrome, but inside piece has been plasti-dipped in dark grey)
Bridgestone Potenza RE003's (265/35/18 rear, 235/45/18 front)
DBA4000 rotors
Bendix ultimate brake pads
Car is registered in the ACT until December 2017 and can be supplied with (+$500) or without RWC. Serious buyers only. No swaps. I'm happy to take potential buyers for a drive, but I won't be offering test drives. If you want any more information about the car, I'm more than happy to help. Thanks
https://www.sau.com.au/forums/topic/472391-for-sale-1995-r33-gts-t-425rwkw/
  • 3 weeks later...
