Hi all,
So basically my Series 1 C34 stag was stolen and I was lucky enough to get it back!
When I got it back I noticed my Xanavi system won't turn on at all BUT my climate control is working and seems to be permanently stuck on auto (my xanavi system houses my climate control so there's no way to turn it off without getting the xanavi to turn on).
Before I go spend some cash on an auto elec to diagnose/ fix, just wondering if anyone's had this issue before or would have an idea of what my problem could be so I could have a more educated look myself?
Would the thief unplug something when stealing the car?
unlucky timing with fuses?
Extra info;
Cigarette/ 12v power still works
my gearshift lights (P R N D 2 1) turn on from time to time but very occasional - worked perfectly before
the light for my "power/ snow" switch still works when in power mode
when I got it back my centre console was popped open (assuming it was done when stealing)
Any help would be appreciated,
Cheers, Nick.
https://www.sau.com.au/forums/topic/472559-c34-xanavi-problems-help/
AS I mentioned on the facebook page, the Xanavi units are known for failing. Usually it is the internal power control unit or dry joints that have happened over time. The units run very hot and the cooling system in them is not adequate for the heat generated.
Does the unit beep when you power on?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
