NISMO GT PRO 2way LSD differential kit - Silvia/Skyline
Back up for sale - I've sourced a GTR axle setup so I no longer have use for this kit - buy it so I can use the money for the rest of my build <3
DETAILS -
This Nismo 2 way diff is up for grabs. Part number is - 38420RS220. It is the model for Silvia's - S13, S14, S15, as it comes with 3 x 2 NISMO half shafts as shown, but can work with all Skylines  from R32 up (not GT-R) with the right bolt pattern half-shafts (5 x 1) and most Nissan's using an R200 diff.
This kit has only been opened to take the picture shown - comes with everything visible in the picture, including Nismo competition diff oil, bolts, gasket, bearings, seals, Nismo half shafts, decals, and NISMO certificate of authenticity.
Prefer pick up on Gold Coast, QLD. But am happy to post wherever necessary Aus wide with cheap Australia Post eParcel or courier rates that include tracking and a signature.
Let me know if you have any more questions.
Price is SAU only special of $1300 flat - advertised elsewhere for $1350.
Edited by GUWOP
https://www.sau.com.au/forums/topic/473216-parts/
  • 6 months later...
Brand new NISMO GT LSD and GT LSD PRO half shafts in 3 x 2 bolt pattern.
Selling as unneeded. Fits the NISMO 1.5 and 2 way differentials but not the stock VLSD or other standard stuff.
Will post or pick up on the Gold Coast, QLD.
$450 or nearest offer takes em.
https://www.sau.com.au/forums/topic/473216-parts/#findComment-7861612
  • 1 month later...
- SSR Minerva Wheels in 17" x 8" - 5x114.3
- Offset is +30/ +35 and all are 8" wide (stickers have come off but I've compared to other wheels I have in + 35)
- Overall good condition, just need a clean and a polish for the lips.
- Slight dent on the inside of one of the rears. Was told it holds air fine.
- Paint in centres is great and original textured finish.
- Can post at buyers expense (cheap rates)
- PayPal ( PayPal fee) or cash in hand only
$1600 ONO
https://www.sau.com.au/forums/topic/473216-parts/#findComment-7866348
Work Japan VS XX Wheels
- measurements are 17" x 9" wide, 35 offset
- Fresh polish on the lips
- Chrome is good on faces but a bit bubbly on the sides of the spokes. Still good on the face of the wheels and not worth worrying about.
- One has some little chips when it tipped over after getting tyres put on.
- Tyres are Yokohama A Drive in 235 / 45 / 17. Freshly installed and balanced. Only used to roll car around while it gets worked on - they are new. Cost $180 each and $40 worth of install.
- Comes with genuine Work centre caps
$1200 ONO
https://www.sau.com.au/forums/topic/473216-parts/#findComment-7866350
Work Wheels Japan VS-SS. Rare and something different to the usual.
These will ideally need a refurbish but could still be used if you don't care about them needing a refurb. No centre caps sorry (didn't come with them).
One rear has had a dent repaired but am told it still works fine.
I dig these but got too many wheels and only 1 car to put them on, so...
SPECS -
- 18 x 8.5 +31 for two wheels
- 18 x 9.5 +31 for the other two
$1350 ONO
Edited by GUWOP
https://www.sau.com.au/forums/topic/473216-parts/#findComment-7866352
  • 1 month later...
Up for sale  -  RHS Quarter cut from R32 GTR.
Comes as is. Good condition besides one dent (easy fix). Wheel arch/Lip not rolled so can be unpicked easily.
Can help with shipping or drop off for extra within SE QLD.
$1200 or trade for RB26 HEAD
https://www.sau.com.au/forums/topic/473216-parts/#findComment-7869274
  • 2 months later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
