WTS: 570cc Nissan injectors & O-rings
Factory vr38dett R35 GTR Injectors, however they have many other applications.
They came out of my R34 GTT rb25det neo and were in working order. They can be installed on a factory fuel rail.
The seals and o-rings were damaged on the way out, but I'm including genuine nissan upper and lower o-rings for a rebuild / service.
One Injector had it's end cap damaged as pictured, will need to be fixed.
I believe they are a direct fit for other nissans such as Z33, Z34, V35, V36 and Stageas.
Located Newcastle, NSW
Can post
$200 neg20180130_200326.jpg20180130_200337.jpg20180130_200407.jpg20180130_200430.jpg20180130_200446.jpg
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/
WTS: R34 GTT factory Diff Centre series 1
Was working before removal, could use a re-shim/ service etc etc.
Removed because I upgraded to a Nismo 1.5 way.
Pickup preferred as it is heavy
$100 neg20180130_193105.jpg20180130_193110.jpg20180130_193116.jpg20180130_193121.jpg20180130_193123.jpg20180130_193125.jpg
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/#findComment-7866586
Should've put it all on one post. My bad
- R34 Gtt front and rear shocks AND pedders lowered springs.
Front shocks are Koni adjustables and probably didn't even go 5000km before I decided to go with coilovers,
Rear shocks are Bilsteins and have no leaks. FORK TYPE!! If you have hicas these will fit.
Dust boots on all shocks are shot and need replacing.
$200 neg
- R34 GTT rb25det NEO factory fuel injectors.
Purchased in working condition from shamrock spares but were never installed. Missing the upper o-rings, but could probably use a service before use anyway.
$60
Located Newcastle NSW
Can post the smaller stuff.20180130_185758.jpg20180130_185805.jpg20180130_185815.jpg20180130_185829.jpg20180130_185836.jpg20180130_185851.jpg20180130_185901.jpg20180130_185910.jpg
  • Like 1
https://www.sau.com.au/forums/topic/473241-more-r34-stuff/#findComment-7866588
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
