Selling a bunch of r33 gtr parts that come off the car due to upgrades or spares that are no longer needed. Prices do NOT include postage, that can be arranged at your expense if required. Local pickup is Townsville, North Queensland. I can get photos if the ones provided are not sufficient enough. This will be updated as I gather the remaining photos/parts to advertise. Will do my best to get back to you as soon as possible with a response.
1. FC-Datalogit for Power FC ECU - $300 firm; These are AUD $400+ brand new, has been used twice when I had a power fc to tune and log some issues. Comes with everything from when purchased new.
2. Power FC L Jetro + Handcontroller + Boost solenoid - $600 firm; Has a mild tune on it currently, was recently removed to upgrade to a Link G4. Not sure on it's flexibility if to be used with other cars (other than r33 gtr), model number in the photo below.
Edited by breaker1845
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/
More Parts added to the list. FC-Datalogit has sold.
2. Power FC L Jetro (RB26 model), ECU only - $400
3. TurboSmart E-boost street with solenoid - $300
4. Oil catch can - $100
5. Front pipe - $150
6. OEM Coilpacks (2 sets) - $100 each, all working and in good condition, removed due to upgrades
7. OEM Fuel rail, regulator and injectors (x2) - $250 each, all working and in good condition, removed due to upgrades
8. R33 gtr OEM turbos (x2) - some shaft play and removed in good condition, kms unknown - $100 a set
9. RB26 OEM Oil Pump - removed due to putting in a tomei - $50
10. RB26 OEM Water Pump - not that old but removed and put a new one in when doing rebuild - $50
11. HKS Exhaust Manifold for twin turbos (brand new was a spare) - $50
12. R33 OEM Cam gears - $50
13. R33 OEM Cam shafts - $50
14. OEM Nissan Head gasket (brand new) - $150
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/#findComment-7869380
  • 4 weeks later...
Bump. Open to offers on the items listed.
I also have a factory R33 gtr long nose crankshaft for sale. Came out of a working motor so its in good condition. Will post up some photos in the next few days.
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/#findComment-7871680
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
