Hi Guys,
Before you say search threads I have both here and on UK skyline forum.
So removed ABS system with a gktech abs delete kit, fitted perfect, my brakes are no good any due to big cams etc and I have kept all standard gear if one day I want to refit.
Also fitted a new transfer case, and bleed it all up seems good, now have 4wd light staying on, check attessa ecu for fault codes we had 3, 2 were easy fix and one has us baffled, it's error code 8 being "abs actuator motor, motor relay or circuit.
We can't figure out how to make this go away, it's like it needs the unit connected to delete this fault but why?
Maybe we need to make it think something is there by bridging wires etc?
Done plenty searches and there is topics on this but all very confusing, any help would be much appreciated
https://www.sau.com.au/forums/topic/473460-atessa-not-working-with-abs-removed/
1 hour ago, Snara said:
Hmm i have deleted ABS unit from engine bay in R33 GTR, but i leave ABS sensors plugged and ECU and 4WD working fine.
Thanks Snara but how are u leaving it connected if it’s removed, if the unit is removed the plugs that were plugged to the abs unit have nothing to plug into.
and mine is a 32 so most likely different anyway
In R33 GTR ABS ECU is in the trunk - he need to stay for working ATTESA. ABS sensors are near wheels they still are connected to the ECU - ECU need to see speed front/rear wheels and it give signal to ATTESA ECU and u have 4WD :D
Maybe in R32 GTR it's different.
Edited by Snara
My wheel sensors are fine and working, atessa not showing any faults with them.
bleed system again, the only time 4wd seems to work (well at least warning light goes out and torque gauge works ) is when I disconnect the bleed connector
its doing my head in
12 hours ago, Anonymouse said:
Firstly - Do you have 4WD?
if so Remove globe
(or trick it into thinking there is an ABS actuator motor connected)
Thanks but removing the globe won’t make 4wd work
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
