Hey there guys as i was heading home the other night over took a car giving my car a bit of boost and then all of a sudden no power on the throttle nothing as i turned onto a side road the car just died still cranks over no lights on dash still primes fuel.I have herd of the CAS shitting itself and it could be the AFM or a pipe that has burst off.Also i have had a problem with the ignition coil igniter but was different symptoms any help of diagnosing whats up would be great cheers. oh also the car is stock as a rock so no mods on the car.
https://www.sau.com.au/forums/topic/473518-r32-gtr-loss-of-power-and-cut-out/
Perhaps an Earthing issue. Cranks but doesn't start, no lights on dash, likely no spark - so check electricals. There is an earthing wire on your ignitor but that wont effect dash lights. Look at fuses/relays.
Edited by Anonymouse
so your ignitor is finally stuffed. Swap a known working one in before you go out and buy a new one. Kudos Motorsports can help you out for a new one.
Just did a search and this is cheap for a new one Link https://www.ebay.com.au/itm/NEW-Ignition-Ignitor-Module-PTU-for-Nissan-Skyline-R32-R33-GTR-GTS-T-RB20-RB26/122450379644?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140106155344%26meid%3D048fb99b6d2e4d3f9cde48b5304c0266%26pid%3D100005%26rk%3D2%26rkt%3D4%26sd%3D131246170269%26itm%3D122450379644&_trksid=p2047675.c100005.m1851
update
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
