Up for grabs is my 2014 SSS Pulsar this car has EVERY mod con available Awesome Xenon headlights, reverse camera, Bluetooth music streaming and phone calls, dual zone climate control, keyless entry, push button start, iPod connectivity, leather interior, sat nav the works!
I'm the second owner of the car, the car was originally from Cardiff (North West of Newcastle) just over 2 years ago now with 54K on the clock. All highway kms verified by the sat nav the car had been all through Queensland and Byron Bay. I drove 3 other SSS' before purchasing this 1 as it by far went the best out of all of them.
Log books are all up to date & I have serviced the car every 10K. Factory calls for 15K service intervals but I believe this is too long.
This car returns great fuel economy I recently drove to Forster and back and returned an average fuel consumption of 5.98L/100km and running around town I get around 7.1-7.4L/100km for a car with 140kw it's unreal! Best of both worlds!
Apart from a K&N panel filter the car is stock as a rock. The car is in mint condition inside and out. The usual stone chips etc but otherwise near perfect. Car is also freshly serviced.
Car has reg till June. Only selling due to company car and gettingthe evo back on the road soon.
Car has 89K on the clock20180317_133738.thumb.jpg.cb5e1c225f9d871e8f634e908e193ab3.jpg
$15Kono
Contact Mick on 0423089277
https://www.sau.com.au/forums/topic/473574-2014-nissan-pulsar-sss-c12/
Thanks! It is a brilliant car. Kind of a shame to see it go. But it my evo needs to take it's place in the shed.
Bump for a great economical daily driver with a bit of zing and great fuel economy!
  • 4 weeks later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
