Hi all,
Looking to sell my 370gt type SP in 6 speed manual which I have had for the past 3 years, need to get something with 4 doors.
This car to my knowledge is the only one in Australia (correct me if I'm wrong) that has had a full english swap for the command centre. This has been achieved using factory Nissan parts, all functions work perfectly including the Navigation which has all Australian maps. This also supports Bluetooth streaming and also has an additional USB cable in the centre console.
It currently has 140, 000 genuine kilometres on the odometer and has not given me a single problem in the 3 years of ownership. The only mod that it has is a Xforce catback exhaust.
There are a few imperfections that I will point out, all the wheels have bad gutter rash on them but were like that when I bought the car. There is also a few scratches on the front right bumper that you can just see in one of the pictures but other than that it is in fantastic condition.
I also have a spare brand new from Nissan blank surround for the steering wheel that has not been fitted to replace the current one that has worn away.
Looking for $23,000 which I think is a fair asking price seeing that it is unique to the fact that it has had a complete conversion to english and is a rare manual.
Open to offers, but not in any rush to sell whatsoever.
Located in Sydney's south west.
If interested PM me or text on 0414 303 233
Thanks
Joe
IMG_20180407_155827.thumb.jpg.20d426deec797c84bdd4fedc151467ac.jpgIMG_20180407_155839.thumb.jpg.44868b705d0f867e9e6a9b1c5dc08d24.jpgIMG_20180407_155855.thumb.jpg.6cb0a672d39c9422bee6fc328fa03eeb.jpgIMG_20180407_155916.thumb.jpg.cb1731d80f69941af1591c01a36b51bf.jpgIMG_20180407_155938.thumb.jpg.282623db95a390d860120b157732f96b.jpg
Edited by FUMIN
  • Like 1
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
hey, i feel your pain, i've have mine for sale for a while and it's only a 60.000km car but i'm fortunate that i don't have to sell, i'd sooner leave it in the shed than give it away, people just don't know class ?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
