Replaced my timing belt with a gates kit once all back together I noticed my cams wobbling. Belt isn’t over tightend, everything was lined up properly and isn’t out of time. Not really sure what else to check any ideas?
https://www.sau.com.au/forums/topic/474239-cam-wobble-after-timing-belt/
What I should of said was I removed the bracket and re installed both dowls weren’t damaged and went on and same result... plan  from now is a find a donnor cas and see if that changes anything other then that I’m cluesless
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
