Hey guys, Hope this is in the right place.
Looking for some help with an issue, have done lots of searching\reading but still unsure. Will try and explain as best I can.
Have an r33 sedan, the factory 25det was really tired. So when doing manual swap I put in a plus t I had that had been freshened up.
All back together, car will not start or run with AFM plugged in. Will start and idle with it unplugged, plug it in while running and car will die. Some have pointed towards fuel pump being an issue. I have a walbro intank pump I will put in over the weekend to try. Have tried a second AFM, same result.
Also, the vacuum line from intake plenum that would normally go to the canister at front of engine bay. If I block this while engine running it will die also which has me stumped.
Any ideas of where to check etc. would be much appreciated.
Cheers in advance.
What ECU?  Asking DET ECU to run from DE AFM or vice versa would not be recommended.
As to the vacuum line....it sounds like it is breathing through this hose at idle.  If you cannot close it, it implies that the idle control valve is not working.
Cheers for the response man,
Car is factory det, loom is all s1 25det, connected to det ECU. and the AFM is the one off the original det motor.
Thanks for the insight on the vacuum issue. Was not sure when it was supposed to be flowing or not. It is breathing through it from idle, so will check the idle control valve plug, piping and clean the valve I guess.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
