Needing help resolving a problem....I have just inherited a saw bench operated by a 6 cylinder L26 engine and gearbox, but the engine seems seized....I haven't looked into what's wrong yet as I have no knowledge of these engines or gearboxes, but I'd like to know what would take its place if it's a boat anchor...
https://www.sau.com.au/forums/topic/474570-l26-engine-replacement/
Almost any engine will do, so long as it is about the same size/power/torque.  These days, the smart thing to do would probably be to find an old Holden/Ford engine, or maybe an old other Nissan/Toyota of the same sort of vintage.  The reason is that anything much newer will be fuel injected, and then you need high pressure fuel pumps, the ECU, sensors, etc etc all working. Old carby/distributor engines are much simpler for this application.
If it were me though, I'd get an engine from a ute.  2.5 or 3L 4cyl fuel injected.
But see if you can oil the bores and get the old clunker turning first.
I am certainly going to try to get the original engine going as it will be easier than having to source a new one not knowing what sort of Nissan this engine came out of....
Thanks for responding
What other engines will this gearbox fit if I can't get it going and can't get another L26 ???
It would have come out of a 260Z or a 260C sedan, seeing as that's about the only cars that had them here in Australia.
2 minutes ago, Bohunter said:
Could you elaborate a little bit more for me please as I'm not familiar with anything Nissan...
Thanks for the input so far....much appreciated...at least I have that engine number you supplied..
Cheers
He's having a joke, because the RB26 is the distant descendant of the L26, and is the motor from the R32-4 GTRs and is the answer to every question (other than those questions to which the answer is LS1 or 2JZ).
Any Nissan L series engine will fit the box.  That's all the 6s and the 4s.  The 4s are a likely to be a little weak for the task.  There were also some other Nissan 4s, with bigger sizes that I think share the same block/box mounting pattern.  I think the Z series are like that, but I'm not enough of an old Nissan tragic to know or care.
I think if you have to change the engine, you would consider changing the gearbox too, because an old manual box for an old Ford/Holden/Nissan/Toyota shitter engine won't break the bank and will vastly open up your options.  To be honest, when you said the engine was running a sawbench, I did not even picture it with a gearbox.  I figured some direct flywheel attachment was in order.
If you really want to power it up, get a 3.8L V6 from an old Commodore, along with the manual box and the necessary fuel injection gear and make it turn the bench upside down on throttle crack!
I pulled the plugs out &  found cylinders 2 & 4 full of water...after blowing out the water I put a cap full of oil in all the cylinders then put tension on the crankshaft and tail shaft/drive shaft with 3 foot stilson and a  fence strainer because I don't have a chain block.... I'll see if anything happens.....
On 7/27/2018 at 8:28 AM, GTSBoy said:
You might have to pull it apart and give it a prostitute's rebuild.
That's why I wanted another engine....I really don't want to rebuild an old engine....
I'd really like to find an old car still running for the engine...
But I don't know what car to chase down...
My 2 cents is anything with a carbie, I've seen a ton of waterpumps running on old 202 motors, hell some old diesel 4 cylinder engine would probably be better torque wise.
You could most likely pick up a old banger for a couple of hundred and then sell the L26 and not lose a cent in the process.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
