Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Sold pending payment:
NEW R32 GTR genuine Nissan Pitwork power steering belt 4PK950
NEW R32 / R33 GTR lower gearbox shifter boot
Used R33 GTR genuine rear upper control arms
Used R32 GTR genuine rear upper control arms
NEW R32 GTR genuine Nissan Pitwork power steering belt 4PK950 - SOLD
NEW R32 / R33 GTR lower gearbox shifter boot- SOLD
Used R33 GTR genuine rear upper control arms - SOLD
Used R32 GTR genuine rear upper control arms -SOLD
TRUST OIL COOLER SOLD PENDING PAYMENT
Trust oil cooler - SOLD
1000CC Denso injectors sold pending payment.
Also now up for sale:
6 X Bosch 2000cc injectors with 14mm adaptors - $400
BPP twin entry 14mm fuel rail - $250
Link G4 plug in GTR ECU - $1500
Make an offer, everything is always negotiable...
  • 1 month later...
SARD / DENSO 1000cc injectors - SOLD
ARP RB26 main studs - SOLD
Used RB26 crankshaft lower timing belt gear - SOLD
R32 RB26 water pump - SOLD
R32 coilpack harness - SOLD
Added for sale:
Camtech CT3536/37 445B R32 / R33 RB26 inlet / exhaust camshafts - 272 deg. 9.7mm lift. Trial fitted only. - $850
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
Price update:
Rb26 Lower timing belt steel cover - -$50
R32/R33GTR Upper timing belt cover -$400
Camtech cams as mentioned above -$750
Rb26 BPP 14mm twin entry fuel rail -$240
HKS turbo - $1300
R32 GTR standard coilovers with lowered springs -$400
First page availability updated.
  • 5 weeks later...
OS88 solid shifter - SOLD
HKS EVC III boost controller - SOLD
HKS EVC IV boost controller not sold due to some people being dropkicks on here. Back up for sale.
Added for sale:
Used Nissan RB26 90A alternator - $150
Used Turbosmart FPR800 adjustable fuel reg in blue - $170
Used Nismo BNR32 front upper control arms with Nismo reinforced bushes - $330 - excellent condition
Used standard R32/R33 GTR blow off valves - $150
Photos added.
Standard R32 GTR coilovers
R32 GTR Nismo Front upper control arms
Turbosmart FPR800 adjustable fuel regulator
OEM RB26 cam gear cover sold pending payment.
Camtech 272 cams dropped to $650. Come on, someone must need some wild cams....
  • 3 months later...
  • BK changed the title to RB26 GTR parts- HKS T51 turbo,RB26 crankshaft,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket, Turbosmart FPR800 fuel reg,BNR32 front arms, R32/R33 GTR blow off valves
  • 1 month later...
Camtech 272 camshafts - SOLD
This makes me a bit sad really as I'll never get them again since they've shut up shop. 😔
Hope they work out well and make that RB26 rev ☺️
  • BK changed the title to RB26 GTR parts- Modified R32/R33 RB26 GT-R transfer case,HKS T51 turbo,RB26 crankshaft,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket,Turbosmart FPR800 fuel reg,BNR32 front arms,R32/R33 GTR blow off valves
Just completed -
Modified 10 plate R32/R33 RB26 GT-R transfer case added for sale. - $2100
Was going to be my spare
  • BK changed the title to RB26 GTR parts- Modified R32/R33 RB26 GT-R transfer case, RB26 crankshaft ,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket,Turbosmart FPR800 fuel reg,32 front arms,R32/R33 GTR blow off valves,GTR front diff
  • 2 months later...
  • 7 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
