Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
On 26/5/2021 at 10:20 PM, BK said:
GTR front diff - SOLD. Second unit still available.
HKS turbo sold pending payment.
Hey mate,
what ratio front diff do you still have? After 4.11.
Thanks
Hi mate. Front diff centre only, not with crown wheel and diff pinion so you can fit whatever crown wheel ratio you want to it.
I have 1 spare set of 4.11 front crown wheel and pinion but keeping it as they are worth a fortune now and have broken them before.
On 22/06/2022 at 8:45 AM, Milhouse said:
Ok thanks but you are right - only after a 4.11 crown wheel and pinion as mine is worn out...
What diff oil you running ? Needs to be 75w-140 or this will always happen eventually.
Can’t remember exactly but wear would have come from previous owner as car had 115k on it when I got it. My diff workshop asked the same question so oil seems to be quite important in these diffs.
Have been looking for a decent cond ring and pinion now for a number of months but looks like I have finally secured one today so fingers crossed!
  • 5 months later...
Time to do an end of year update of things for sale:
Precision ball bearing Gen1 6266 turbo T4 divided 0.84 a/r SP cover - requires rebuild on chra, Slightly passing oil but will smoke if used, otherwise ok. Can be rebuilt locally by Rose rage turbos or sent back to Precision - $1100
Trust T78-29D turbo, T4 divided - requires rebuild on chra. Same as above passing some oil on seals. Easy to rebuild with genuine Mitsubishi parts - $900
NPC 10" single plate push clutch rated to 450kw. NPC7056B-10 Good condition, suit all RB push setups - $700
New in box Turbosmart OPR T40 turbo oil supply pressure regulator - $140
RB26 R33 flywheel - $200
NEW Prosport 60mm dual stepper motor type JDM series 40psi electronic boost gauge with pressure sensor, harness and 60mm gauge cup. Has dual analogue needle and digital readout, programmable warning light. - $220
Used BPP 14mm twin entry fuel rail, anodised black, no mounting spacers - $150
Used Nissan RB26 90A alternator - $150 (maybe I should keep this...)
Used standard R32/R33 GTR blow off valves - $150
Used Turbosmart FPR800 adjustable fuel pressure regulator in blue. Fitted with AN6 male flare inlet and 5/16" hose barb outlet fittings - $150
Used BNR32 front upper control arms - $150
Used RB26 lower front belt timing cover like new - $60
2 X New RB26 genuine NIssan head gasket 11044-05U16 - $90 each (rrp $130)
Used 60mm electronic boost gauge, 1.6bar max with MAP sensor. 60mm gauge cup included. Remote peak / hold controller - $90
3 x R34 GTR lower shifter bush - $10 each.
Used R32 / R33 GTR pull clutch slave cylinder and hose - $90
Used Rear R33 GTR sway bar - $90 (Good S14 or S15 upgrade)
NEW R33 GTR / GTS25T STS Performance (made in UK) 3 ply silicone lower radiator hose in RED from GCG turbos (not chinese ebay crap) - $45
Used R32 GTR front diff centre - $200
USED R33 RB26 LONG NOSE CRANK, unknown condition, has surface rust - $500
Carbon fibre N1 bootlip spoiler -$250
FRP N1 bootlip spoiler in TH1 blue - $200
Used Bosch 044 fuel pump - $100
Used SARD / DENSO 1000cc injectors. Low impedance , 0.85ms latency. Fit 10.5mm (standard) or 11mm fuel rail. - $400
Tomei sump baffle kit - $150
More to come when I think of it
  • BK changed the title to Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
